Abs issue
Old Aug 22, 2024 | 07:07 PM
Gilly389's Avatar
Gilly389
2nd Gear
Default Abs issue
I have a 1990 c4 convertible left front caliper dragging I've bought a used abs pump came with all electrics mine has a orange tag apparently (1900_91)
new one that came with the pump is green (1986_1989) will this work in my 1991my I use the pump with the included green module ?? Please help guys !!!
Old Aug 22, 2024 | 07:18 PM
Whaleman's Avatar
Whaleman
Mtechnique ABS – MTechnique ABS
This company rebuilds them. The man is an expert. If you ask him a question on his contact us form I suspect he will answer and I also suspect his answer will be correct. Dan
edit: The problem with used ones is they are sometimes just as gunked up as your old one.
