Leaking Clutch Fluid
Old Feb 5, 2003 | 08:40 PM
89CONV's Avatar
89CONV
Default Leaking Clutch Fluid
My fluid has been leaking for a long time and now it is time do fix the leak. I first searched the archives and found that Advanced Autoparts had a rebuild kit for under 30 dollars, but they say it is no longer available. I do not want to buy a new system, so where else can I buy just a rebuild kit (if "Bob" from Advanced Aut is right) or exactly what parts are needed that I could source at the local auto supply shops? For my Canadian friends, Canadian Tire has a master cylinder "kit" for the clutch and they are charging 54.95 Cdn, but they have no idea what it consists of. Can anyone offer some guidance? :banghead:
Old Feb 5, 2003 | 08:58 PM
REW89's Avatar
REW89
Default Re: Leaking Clutch Fluid (89CONV)
I just did mine but replaced the master and slave as new units. I read numerous posts on the various Vette forums that scared me away from trying to repair my existing ones. Evidently many folks who try this find the repair does not work as well as anticipated or not at all.
Good luck. Bob White :)
Old Feb 5, 2003 | 09:03 PM
frank moran's Avatar
frank moran
corvette cent. has both kits for under $25. i did both about 4 months ago...
Old Feb 6, 2003 | 09:00 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Buy the replacement units...save your self trouble in the long run....hard to rebuild these units....
tony
:thumbs:
Old Feb 6, 2003 | 09:19 PM
brimee's Avatar
brimee
I got my replacements at NAPA. They had the most resonable price and they are manufactered by the same company that made them for GM
Old Feb 10, 2003 | 07:12 PM
89CONV's Avatar
89CONV
Pulled them out on the weekend and the master looks good (hard to get out), but the slave it shot. Would it be wise to also change the lines or are these problem free? As an aside, there is a metal looking solenoid behind the slave cylinder that has a wire connection (which was unplugged) and my Haynes manual does not show it. It has a bunch of numbers with 100% stamped below. Any idea what this is for and why it might be unplugged? :cheers:
To Leaking Clutch Fluid
