Fuel Pressure Drops Immediately 86
Old Nov 13, 2024 | 09:32 PM
21boy's Avatar
21boy
Default Fuel Pressure Drops Immediately 86
Hello C4 Forums,
Like the title says, I've been having rough cold starts, takes 20-40 seconds to turn over then runs fine.
Checked the relay and it's working. Hear the fuel pump engage when key is turned to ON, and with fuel pressure gauge connected to shrader valve I get the correct fuel pressure of around 43 psi before it stops to 0 shortly after the fuel pump is done priming.
I hear no signs of leaks and smell no gas near the engine bay (which is good) but I did just rebuild the fuel rail and do new injectors because I had a gas smell. What or where else should I look for leaks? Or how?
Old Nov 14, 2024 | 06:44 AM
Incorvettei's Avatar
Incorvettei
Did you check the fuel pressure regulator? Pull the vacuum hose off and see if you smell gas
Old Nov 14, 2024 | 08:28 AM
21boy's Avatar
21boy
​​​​​​Disconnected and jammed it in my nose. No not really. I also replaced the bladder when I redid everything.
Old Nov 14, 2024 | 06:37 PM
NavAir's Avatar
NavAir
Mine (89) had similar symptoms recently, turned out to be bad hose connecting the fuel pump to fuel line (replacing the pulsator) inside the tank. If you have a FSM, go through the diagnostic chart (involves clamping of supply and return lines and observing fuel pressure). That will steer you in the right direction.
Old Nov 14, 2024 | 11:26 PM
sheriffjim's Avatar
sheriffjim
I agree with NavAir, if it is bleeding off to 0 in a very short amount of time it is likely something with the pump. There's a check valve inside the pump, or it could be a bad connection.
Turn the key to on to pressurize the fuel system. As soon as you hear the fuel pump stop priming, clamp the feed line at the tank. Then check your gauge. If the pressure is holding, the problem has something to do with the pump. This is easier to do with another person, as you have to be kind of quick to clamp the line right after the pump shuts off.
If the symptoms persist, you can try clamping the return line (this time before you prime the system), which will test for a pressure regulator problem.
Old Dec 27, 2024 | 11:23 AM
21boy's Avatar
21boy
Dumb question, I installed a braided sending line from JEGS that uses AN Fittings and an adapter. I know there was not an oring on that adapter because of the flared end and JEGS told me that's fine, but could this be the issue? Adapters on filter and fuel rail sides.
I lose pressure almost immediately and this was not like this before replacing the line.
Old Dec 27, 2024 | 12:25 PM
Nilak's Avatar
Nilak
I've thought of a method that should tell you if it is the pump or the regulator. you could blow air with a bycicle pump through the pressure line and see after the line pressurises, how quickly does it go to 0. I assume the pump has an anti drain back valve and it is likely it is leaking imo, if you said the regulator seems fine. Other than that, a leak anywhere else, like the injector or the line, you would smell the gasoline or would flood the cylinder, so it is less likely.
Old Dec 31, 2024 | 03:19 PM
21boy's Avatar
21boy
Love you for the inspiration. I ended up taking off the pressure line at the fuel sender and rigging up a bike pump there to deliver ~40psi into the system and ran to the engine bay to listen for any air hissing.
I think I found it... Diaphragm was pulled/broken by one screw. I think it wasn't smelly because it was on the underside of the plenum and hard to hear/see any gas signs. It's either that or a cross member o ring.
Ordered the Holley adjustable because this bolt tightening non sense is horrid for a fuel adjustment under the plenum. Fingers crossed, it should help greatly! Will keep updating until solved...
Old Dec 31, 2024 | 06:10 PM
Nilak's Avatar
Nilak
I’ m glad that helped.
About the Holley regulator, you need to set it up to behave like the stock one especially at high load where Power Enrichment is based on the 3d map and other parameters otherwise it will alter the air fuel ratio. for example if the pressure at high MAP is lower it could run too lean, if it is higher then stock it would run richer. for example if the original psi is 35 psi at high load and you set it at 45psi the fluel flow will increase by sqrt(45/35) and AFR will go from 11.8 :1 to 10.4:1 which is a but too rich
Old Jan 1, 2025 | 09:01 AM
21boy's Avatar
21boy
Any suggestions then for setting the variable regulator? I had the South Bay version previously and I just sent to what I saw the recommended pressure was, believe 42.5psi for the Boshe D3, 22lb injectors.
Old Jan 2, 2025 | 04:47 AM
Nilak's Avatar
Nilak
42 or 45 should not make a difference. At low load the ECM uses the O2 sensor to adjust the AFR to 14.7:1 then it sets some BLM cells slightly different. However, at high load where the vacuum is less present the computer expects a lower pressure, I don’t remember the value, possibly it is going down to 35psi. do you have a vacuum port for your Holley regulator?
Old Jan 2, 2025 | 07:13 AM
bjankuski's Avatar
bjankuski
Set the pressure at 43 PSI with the vacuum line disconnected and the car idling. AT WOT there is no vacuum so the pressure will be set at 43 PSI and then when you close the throttle for cruising and idle the vacuum will reduce the pressure to keep the fuel pressure across the injectors the same with the higher intake manifold vacuum (Pressure differential) . That is why the regulator is vacuum referenced.
Old Jan 9, 2025 | 12:44 PM
Nilak's Avatar
Nilak
Sorry, I got it backwards; thanks bjankuski for the clarification
So it is high pressure (43) with no vacuum aplied; that makes sense, to have higher pressure at WOT.
This is the important pressure to have it accurately set, with the vacuum disconnected. Then at idle with the vacuum line connected, it should go 30ish, small deviations from what the computer is calibrated at can be handled by INT/BLM.
21boy - did you fix it?
To Fuel Pressure Drops Immediately 86
