Modified Dana 36 cover
Old Feb 8, 2003 | 10:04 AM
gene284's Avatar
gene284
Default Modified Dana 36 cover
The Dana 36 was taken out for new gears. While it was out, we removed the perch and retainer for the transverse leaf spring, since we are running coil overs. Trying to make the assembly look simpler.
We traced the rounded contour out to the ends by milling, and then made an angular cut to remove the bolt holes.
Old Feb 8, 2003 | 10:09 AM
BBA's Avatar
BBA
Default Re: Modified Dana 36 cover (gene284)
Seems odd that after all the work your doing and going with a supercharged motor...why not splurge for a rear end that will survive the power?
Old Feb 8, 2003 | 10:20 AM
gene284's Avatar
gene284
Default Re: Modified Dana 36 cover (BBA)
Have a low mileage Dana 44 with 3.33 gears (1989), and a Dana 36 with 3.07.
The 44 was scheduled to go into the car, but as we mounted the differential casing to the frame with the 36, it would involve some modification to install the 44. Having painted the frame, couldn't step up to modifying it already. :)
The 44 are indeed nice rear ends. Used on Studebakers solid axle housings in the 50's. The more things change, the more they stay the same. Who would have thought todays premier sports car would be using it?
Hoping to use the 44 on another project.
Old Feb 8, 2003 | 10:34 AM
BBA's Avatar
BBA
Well...with supercharged power...I hope you don't blow up the 36 too many times then. :D
Old Feb 8, 2003 | 06:02 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
:iagree:
To Modified Dana 36 cover
