Stalling issues when driving!
Old Feb 8, 2025 | 06:07 AM
Nicholasv969's Avatar
Nicholasv969
2nd Gear
Default Stalling issues when driving!
Just bought a 1988 c4 and had a idle issue, i replaced the distributor rotor and cap and the spark plugs and the check engine light went off but the car still idles weird (500rpm -700rpm) and sounds like it wants to die out. When driving it feels normal but when i push the gas past a quarter way it bogs and cuts power completely and stalls out. Anyone have any clue what could be a issue???
Old Feb 9, 2025 | 12:54 PM
Macaroni Kid's Avatar
Macaroni Kid
When was the last fuel filter change? Or fuel pump? They tend to give a little notice before completely quitting out
Old Feb 9, 2025 | 09:34 PM
Nicholasv969
2nd Gear
Fuel pump was replaced when i bought the car but fuel filter age is unknown. The car revs and idles well now i cleaned a couple sensors but it still bogs when driving and proceeds to stall out.
Old Feb 10, 2025 | 10:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Was there a code stored from SES light ?
You might want to do a minimum idle and throttle position sensor adjustment.
Has timing been checked ?
Old Feb 10, 2025 | 03:59 PM
Ted1996's Avatar
Ted1996
Check this out. Solved my idle issues on my 1988. Someone messed with the minimum idle speed screw (thinking it was just an idle screw ???) and the TPS (throttle position sensor) was not measuring proper voltages. I replaced both the TPS and the IACV after cleaning the throttle body. Idled better, started better, and AC cycling was better. Start by checking the TPS; voltage at idle, then smooth increase up to full throttle. If I remember correctly, L98 needs a minimum of 4.5V at full throttle to invoke power enrichment mode. I used an OBD1 scanner to set minimum idle speed and double checked with a handheld digital tachometer.
https://www.corvetteforum.com/articl...ps-idle-speed/
To Stalling issues when driving!
