puzzled
Old Mar 20, 2025 | 12:23 PM
JKann12's Avatar
JKann12
Navigator
Default puzzled
I have a 84 crossfire engine it was running great and then poorly so I changed the plugs but now not so good it turns over backfire a bit but nothing won't even run I'm lean toward the ignition module.. got any Idea's Thanks for your time
Old Mar 20, 2025 | 12:37 PM
s carter's Avatar
s carter
There's a few things to look at find a length of hose that you can Syphon off a Fuel sample off FROM THE BOTTOM OF TANK into a jar look for water contamation it's one of those things when you got it running gets worse. Next how's the spark, like in your thinking a Coil? ICM? are both injectors popping?
Old Mar 20, 2025 | 02:20 PM
typical boomer's Avatar
typical boomer
You may have probably already done this but check again that the plug wires are connected to the plug they are supposed to be on. Ask me how I know.
Old Mar 20, 2025 | 03:27 PM
conniekalitta's Avatar
conniekalitta
We live the same life. I was worried I have faulty ignition components from the big O'Reilly the other day. Nope, just me being a moron and installing the wires wrong. The engine will crank and crank forever and make smells but not turn over.
Old Mar 20, 2025 | 10:42 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Backfiring out the intake indicates lean.
Replace the fuel filter along the frame rail near the passenger side door hinge under the car
Old Mar 21, 2025 | 12:53 PM
marshallnoise's Avatar
marshallnoise
I assume you didn't touch the distributor?
To puzzled
