OBD I Scanner
Old May 25, 2025 | 12:33 PM
hgoodwiniii's Avatar
hgoodwiniii
Default OBD I Scanner
Hi everyone, what's everyone using for to read pre 96 OBD I check engine codes and live data? My car is a 91.
My old Auto Xray (705-001-02A) looks to be fried due to battery corrosion.
Also, anyone happen to know where they can be repaired? Thanks.
Old May 25, 2025 | 08:22 PM
CorvetteRules's Avatar
CorvetteRules
I use a CP9690 Elite AutoScanner which does OBD 1 and 2, It does have the ability to collect data. Don't think it is made anymore but you could probably find one on ebayor Amazon.
Old May 25, 2025 | 09:16 PM
ULTM8Z's Avatar
ULTM8Z
Have you tried cleaning the terminals in the scanner?
Old May 25, 2025 | 10:58 PM
hgoodwiniii
Thanks - I had no luck with cleaning the terminals. I will give it another try. Thanks
Old May 27, 2025 | 11:28 PM
C4industries's Avatar
C4industries
Your 91 runs the 7727 speed density ECM. There's TONS of free tuner support for this ECM. I recommend buying the OBD1 ALDL cable from moates.net. It's $80.
https://shop.moates.net/products/aldu1-and-cabl1
Then download the free version of TunerProRT to a PC laptop. You'll be able to read all live stream data with this setup.
Check engine codes come direct from jumping pins on the OBD1 connector and reading the blinking CEL codes on the dash.
Old May 27, 2025 | 11:51 PM
LightningBrett's Avatar
LightningBrett
I have a like new Auto Xray easy scan 6000 OBD 1 & 2, I would sell for $120 shipped. It is the complete kit w/enhanced domestic software up to 07, 6 cables and a case...
Old May 28, 2025 | 08:04 AM
hgoodwiniii
Ah ok, I'll give it a try. Thanks.
To OBD I Scanner
