1985 Cruise Control Issue
Old May 28, 2025 | 02:54 PM
85 Z51's Avatar
85 Z51
Default 1985 Cruise Control Issue
About a week ago I had a strange issue with my cruise control. Got on the highway and set the cruise at 65. The car slowed to about 60, then accelerated to almost 70. Tapped the brake to shut it off, then tried again. It did the same thing again, so I just urned the cruise off and finished my journey. On the way home I tried it again and the cruise would not engage at all. Testing it on a drive again today it still did not work.
I have traced all of the vacuum lines and cannot find any issues. Tried pulling up on the clutch and brake pedals together while setting it - no luck. Tested the vacuum check valve and it seems to work normally (ordered a replacement anyway). HVAC controls all seem to work normally. I also pulled both lines off of the servo, and tried plugging them with my fingers. It will not hold a vacuum with either or both ports plugged. It makes a hissing sound while trying this test bit I cannot feel where any air is escaping.
My current guess is that I need a new servo. Anyone else have this experience? The way it acted up initially makes me think it is vacuum related.
Thanks!
Old May 28, 2025 | 09:43 PM
gerardvg's Avatar
gerardvg
Thanks!
I had an issue with the brake pedal switch on my 85 some years ago, the switch could be disassembled was a bad contact on the plunger inside the switch. Something to look at. Was some time ago and would work here and there when tapping the pedal... worth a look perhaps, good luck 👍
Old May 28, 2025 | 11:11 PM
85 Z51's Avatar
85 Z51
Thanks, I will look into that tomorrow.
To 1985 Cruise Control Issue
