can't shift into 1st or 2nd
Old Jul 14, 2025 | 03:16 AM
racingwiththewind's Avatar
racingwiththewind
Navigator
Default can't shift into 1st or 2nd
1996 LT4 with ZF manual transmission. Was shifting fine during 1000 mile roundtrip in the past week. Got home and found I could no longer move the stick into 1st or 2nd gear. Any ideas of what the issue and fix is?
Old Jul 14, 2025 | 04:17 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Check the hydraulic clutch fluid.
Old Jul 14, 2025 | 07:15 AM
bjankuski's Avatar
bjankuski
Will it shift in with the engine off? If the answer is yes then the clutch is dragging and that could be a sign of low clutch fluid or some other issue with the clutch release. As noted check the fluid first.
Old Jul 14, 2025 | 05:00 PM
Elduderino's Avatar
Elduderino
Clutch fluid, does it ride smooth by the way?
Old Jul 17, 2025 | 02:17 AM
racingwiththewind
Navigator
Checked clutch fluid. All good. Drives, rides and shifts smoothly. I have to pull hard with both hands to get the shifter over far enough to engage 1st or 2nd. I don't see a way to upload a video here. https://photos.app.goo.gl/CcCCvSpEk9w4w8837
Old Jul 17, 2025 | 02:34 AM
racingwiththewind
Navigator
fluid ok
Old Jul 17, 2025 | 04:43 AM
kenmohr's Avatar
kenmohr
Originally Posted by racingwiththewind
fluid ok
check for sloppy linkage.
Old Jul 20, 2025 | 12:15 AM
racingwiththewind
Navigator
Thanks. How would I check for sloppy linkage? Best I can find is to pull out the transmission to check for damage. I was hoping for something easier and less expensive. I live in a remote community in Northern British Columbia. I may have access to the local high school's lift next month. No local mechanics that I would trust my car with.
Old Jul 20, 2025 | 05:28 AM
kenmohr's Avatar
kenmohr
You may need a friend. Shift the shifter while a friend watches the levers on the trans and make sure they are moving the full length or at all.
OOPS just noticed your is stick shift. Mine was auto. Hang in there someone will help.
Old Jul 24, 2025 | 02:40 PM
NickPSI's Avatar
NickPSI
This may be an issue with the shifter itself. Thumb through this thread for some ideas.
Im in camp 4+3 for my trans knowledge so I don't know the shifter on the ZF well.
https://www.corvetteforum.com/forums...with-pics.html
Old Jun 4, 2026 | 12:27 PM
racingwiththewind
Navigator
I'm hoping that someone can help with this issue. My car has been stored for almost a year now. I need some advice on where to start with this project. I have a small garage but no lift so I was thinking to raise the vehicle up about 2 feet on blocks and start removing the supporting cross members (convertible) and the exhaust system to get access to the clutch and transmission. I have basic tools and DIY mechanical skills. I'd love to do this myself and there are no local mechanics that I would trust in this tiny northern community. Thanks!
Old Jun 4, 2026 | 01:45 PM
2011KLR's Avatar
2011KLR
If you can get it to shift into first, albeit with high force, I would say that the transmission internals are OK. The shifter/linkage are/is your problem.
Spitballing....
Is it at all possible something fell down into the shifter housing and has lodged itself so that it prevents you from easily all the way left to get it into that gate; something like a quarter or a toothpick or a bottlecap???
I also have the 4+3 so I don't know what or how all of the ZF shifter linkage sits in there.
Old Jun 4, 2026 | 01:51 PM
racingwiththewind
Navigator
Thanks. It looks pretty clean in there
Old Jun 4, 2026 | 01:54 PM
2011KLR's Avatar
2011KLR
I know that those ZFs had that CAGS stuff. I wonder if the lever/plate/thing that forces the 1-4 shift is broken and is preventing you from getting back to the 1-2 gate?
Old Jun 4, 2026 | 02:12 PM
racingwiththewind
Navigator
I have reached out to Bill at ZFdoc to see if he has any suggestions. Maybe I just need a new clutch?
To can't shift into 1st or 2nd
