GM Code reader unable to pull codes from ECM
Old Jul 15, 2025 | 03:59 PM
Thomas DeLucco's Avatar
Thomas DeLucco
Cruising
Default GM Code reader unable to pull codes from ECM
Afternoon All; I own a 1994 C4 Corvette. I have a "service engine soon" light that will come on intermittently. My question though is, I can not get any codes out of the ECM with my code reader. My Corvette shop can't get codes out of the ECM. Has anyone else who owns a late model C4 had this problem? Would anyone have an idea why the ECM won't transmit the codes to the GM Code reader? Or, do I need to use the "paper clip" method?
Thanks for any and all help Corvette Forum
Old Jul 15, 2025 | 04:09 PM
84C4Tom's Avatar
84C4Tom
For all practical purposes the 94 is a OBD 1 system. But it does use the OBD2 ALDL connector. A OBD2 code reader will not work if you hook it up.
I believe OBD II started in 96. Other more knowledgeable people will likely chime in.
Old Jul 15, 2025 | 04:13 PM
WVZR-1's Avatar
WVZR-1
If you have the FSM(Factory/Field Service Manual) spend some time in Book 1, 8D Section and learn the diagnostic procedures using the DLC connector and the DIC Control for all of your diagnostics. You can accomplish most everything needed using the DLC and the DIC Control. Do you have the FSM?
Old Jul 15, 2025 | 10:03 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Idk if this would work on a 94 but seems to apply to 95 which are still obd1...
https://ls1tech.com/forums/lt1-lt4-m...1-scanner.html
To GM Code reader unable to pull codes from ECM
