Heater hose flow control fitting
Old Jul 20, 2025 | 03:13 PM
Yguy's Avatar
Yguy
Default Heater hose flow control fitting
I’m hoping for some help guys,
my project is an ‘89 with a 383 small block. It’s been a looong time coming for this project and when I got it on the dyno it blew out the heater core. I recognize age could have been the issue, but before I go too far I need advice. The engine was out when I got the car so I have no reference on it.
Where does the heater flow control valve go, on the intake manifold or in the side of the water pump? I’ve got a valve on the way, but I need to know where it goes.
thanks for any help/advice you can share!
Old Jul 20, 2025 | 04:12 PM
Aardwolf's Avatar
Aardwolf
From memory it was around the passenger exhaust manifold but I remove those valves usually. With water flowing through the core full time it's less likely to have corrosion issues from my experiences.
Old Jul 20, 2025 | 05:32 PM
Yguy's Avatar
Yguy
I’m not sure where on the exhaust manifold you’re describing, but the one I’m using looks like a regular hose fitting that screws in the intake manifold or water pump. The valve part of it is a one-way valve inside the fitting.
Old Jul 20, 2025 | 07:03 PM
Aardwolf's Avatar
Aardwolf
The thermostat?
The water valve to stop anti freeze going to the heater core in summer can be anywhere, I remember it being around the exhaust manifold area. Put it anywhere there is room or put stock hoses on and it should be obvious then. I usually buy my own heater hose and cut to fit so I don't know if stock is available.
Old Jul 20, 2025 | 07:11 PM
1Hotrodz's Avatar
1Hotrodz
Small block Chevy has the heater control valve mounted to the intake. So supply ( for the heater core) from the intake manifold to the heater valve to the heater core and return to the pump.
Old Jul 20, 2025 | 08:10 PM
Yguy's Avatar
Yguy
The thermostat?
Thanks for the help ‘Wolf!
Stock hoses aren’t really available. Some places have hoses that are plumbed with plastic T-fittings, but the OEM was all molded. Either way, my car was a big model kit when i got it and now I’m trying to figure out what’s what.
Old Jul 20, 2025 | 08:11 PM
Yguy's Avatar
Yguy
Thank you! This is what I was hoping for! Very much appreciated!
Old Jul 20, 2025 | 10:15 PM
Aardwolf's Avatar
Aardwolf
I think this is the part you want https://www.rockauto.com/en/moreinfo...t=6860&jsn=791
I thought you were talking about the valve that is on the heater hose.
Old Jul 20, 2025 | 11:34 PM
Yguy's Avatar
Yguy
Sorry for any confusion on the part name. It was my understanding the part was called a valve. As it happens I have one on the way!I guess I need to put it into the manifold to feed the heater core and then the other hose back to the water pump.
Now I’ll need to find a day to swap out the heater core.
Thanks again!
To Heater hose flow control fitting
