96 C4 manual conversion
Old Aug 12, 2025 | 09:18 PM
cycle409's Avatar
cycle409
5th Gear
Default 96 C4 manual conversion
Hi Guys
Has anyone ever put a T10 with the Nash overdrive unit in a 9/596 model C4. My question is how to make the VSS in the old t-10 transmission work with the new wiring/car. Both have 2 wire electronic connections but the VSS unit is a completely different design. I can reprogram the ECU if I can get a any kind of signal from the drive shaft VSS. I'm just not sure what to do with wirers and if the systems are at all compatable.. Any kind of conversation kit would be great. Any other ideas would be appreciated.
Old Aug 13, 2025 | 02:39 PM
skorpion317's Avatar
skorpion317
2024 C4 of the Year Winner - Modified
Serious question - why would you want the old 4+3 transmission? The ZF6 would be much easier to swap in, has overdrive gears built into it, and is much more reliable vs. the Nash overdrive unit.
Old Aug 14, 2025 | 06:18 AM
Pale Roader's Avatar
Pale Roader
Wouldn't that be like swapping in an old flathead into a Coyote Mustang?
To 96 C4 manual conversion
