1986 engine suddenly dies while driving, refires instantly
Old Sep 2, 2025 | 08:57 PM
RWDsmoke's Avatar
RWDsmoke
If you are coasting and the motor is still turning it should show rpms until it stops. Tach showing Zero rpm's while coasting with the motor still turning means no ignition pulses. No ignition pulses will shut off the fuel injectors, but no fuel will not affect ignition pulses.
Old Sep 4, 2025 | 11:13 AM
boneymon's Avatar
boneymon
error
Old Sep 4, 2025 | 06:40 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The fact that it just turns off, suggests that there is no reference signal to ecm. You may want to try another module. When my pickup coil started to flake out, it took more than an hour before I could restart.
Old Sep 6, 2025 | 11:04 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
https://www.corvetteforum.com/forums...post1606928944
scroll down from that link. possible cause. felt like it just shut off. i thought it was electrical thats how abrupt it was. fuel sock plugging. mine got so bad it would plug, then if have to restart, while rolling. i put a cleaner in the tank, which exacerbated the issue because it caused the fine particles to come loose and get caught up in the intake sock.
video confirming diagnosis is in thete and fuel sock is in post 55. it was sucking closed.
