Injectors not firing
Old Nov 14, 2025 | 08:15 PM
Tunedport90's Avatar
Tunedport90
OPPs sorry I missed that , saw no injector pulse and jumped to a conclusion
Old Nov 18, 2025 | 06:40 PM
TacoTom22's Avatar
TacoTom22
Originally Posted by IHBD
"VATS" does not disable spark or the fuel pump. Only the injectors and starter. It should fire on starter fluid even with an active VATS.
The SECURITY light should never be ON with the key in RUN. If it is on, it is indicating a VATS inhibit, or if the engine is running a problem with the key resistance circuit. (Warning the driver that it may not start the next time.)
It is possible that a previous owner bypassed the starter relay. If the factory alarm is functional, there is a way to test if the starter relay is still active:
  • Get in the car.
  • Have the ignition key in your hand, not in the lock.
  • Lock the doors with the power door locks. The SECURITY light should go solid-on.
  • Close the door. SECURITY light should go off after a few seconds. The alarm is armed.
  • Insert the key in the ignition, the horn should start honking. If it doesn't, turn on the park lights as they are also a 'wake-up' that will set off the alarm.
  • With the horn honking, attempt to start/crank the engine. (It shouldn't crank because the CCM also disables the starter if the alarm is set off.) If it cranks, the relay is bypassed.
  • Get out of the car and disarm the alarm with the door key.
If the alarm is functional, and disables the starter when set off, the starter should also be disabled by VATS. If it cranks, it is not "VATS".
Unless the Fuel Enable requirement has been eliminated with a custom chip/tune, the really easy thing to do and remember is that the SECURITY light should never be ON with the key in RUN. If it is, there will be no injector pulse.
Didn't remember to check the alarm this afternoon but I did take notice that with the key in the run position, the security light flashes 3 times every 12 seconds or so.
Old Nov 18, 2025 | 07:59 PM
Tunedport90
I’m wondering if it’s vats, I can program it out for you
Old Nov 18, 2025 | 08:48 PM
IHBD's Avatar
IHBD
Pro Mechanic
You have a Code 54 in Module 1, the CCM.
Code 54 is Fuel Enable Failure. The FE uses the data link between the ECM and the CCM to perform a password exchange routine when the ignition is turned ON. If the password routine is not successfully completed within 2 seconds, Code 54 will set and both the SECURITY and SYS message flash together. (This is the only code that flashes the SECURITY light in RUN.)
I'm suspicious that you still have an ECM communication problem. Code 1.54 is a problem with the ECM even though it shows in the CCM trouble codes. You do not have a basic "VATS" problem because the SECURITY light is not solid ON. "VATS" is ok. The ECM is not.
If it cranks with a triple flash SYS and SECURITY light, the starter relay has been bypassed.
Originally Posted by Tunedport90
:yup: can also back or a19 to see if there is 50hz from the passkey module at 50-60-%
A 1992 does not use the square wave signal. It uses the Fuel Enable handshake between the CCM and ECM on the serial data buss.
Old Nov 19, 2025 | 01:17 PM
TacoTom22's Avatar
TacoTom22
If I can't pin down what the problem actually is I may have to go that route
Old Nov 19, 2025 | 01:22 PM
TacoTom22's Avatar
TacoTom22
Could it be possible that the data line that connects all the computers/modules is causing a problem? Ive checked to see if it was shorted to ground, which it isn't, haven't checked yet if all the connections were solid.
Or even if the ccm may be faulty, I'm highly suspicious it's not the cars original.
Old Nov 19, 2025 | 10:00 PM
IHBD's Avatar
IHBD
Pro Mechanic
[QUOTE=TacoTom22;1609251258]Could it be possible that the data line that connects all the computers/modules is causing a problem?
Can you read Module 9 codes or "- - - " with the onboard diagnostics? Module 9 is ABS/TCS. If the CCM can read Module 9, the data buss is ok. Module 9 is independent of the ECM and CCM.
Another check with the C68. Hold arrow up and arrow down until " -00 is displayed. Push arrow up until "016" is displayed. Press fan icon. 016 is engine coolant temp in deg C. If no reading, the data may not be present because the ECM is not sending it.
Highly unlikely. CCM failures on here are non-existent. I've never seen one.
The CCM is doing a lot of things right. It is processing Code 1.54 correctly. It is processing the LCD. It is processing the onboard diagnostics.
Does the odometer reading seem about right for the general condition of the car? Replacement used CCMs will have the donor car's odometer reading. It can not be changed.
I think your ECM has to go back to SIA for a recheck. If it is ok, you need a prom or carrier, or something.
Old Nov 23, 2025 | 03:28 PM
TacoTom22's Avatar
TacoTom22
[QUOTE=IHBD;1609252282]
The odometer reading is very low. Mid 30k if Iremember correctly. Been the same owner for the last 20 plus years, peeking under the valve covers I was originally incled to believe it. Ran a carfax and back in the 90's the car was stolen and reported that odometer reading now accurate.
New (to the car) memcal was installed. Same issue.
Regarding another post I had made in the forum, about an aftermarket ecu fixing the potential memcal problem, do you think it would solve whatever issue this is turning out to be? If I were to piggy back it off the stock and just run the fuel delivery and ignition system off it?
Old Nov 23, 2025 | 04:04 PM
TacoTom22's Avatar
TacoTom22
  • Get in the car.
This cars problems keep growing, electric locks don't work and the security light never goes solid
UPDATE: Kept fidgeting with the door locks and got them working.
Armed the alarm and got the solid security light, used the lights to trigger the alarm, as soon as I put the key in the ignition the alarm turned off and the security light when back to flashing. Then same issue with the 3 flashes. Timed it this time and it was every 20 seconds.
Old Dec 1, 2025 | 11:21 PM
Repulsive_War_018's Avatar
Repulsive_War_018
8th Gear
C4 no-injector pulse = 95% no power or ground to the injectors.
Quick checks:
  1. Pink wire at any injector – key ON should have 12V. No? Check ECM fuse and pink wire from relay.
  2. Dark green/white wires – should pulse to ground when cranking (test light flashes). No flash = bad ECM, bad distributor pickup, or bad ECM ground (G104 behind driver headlight).
Pull codes first, then check those two things and you’re done. Takes 5 mins. Good luck!
Old Dec 3, 2025 | 03:46 PM
TacoTom22's Avatar
TacoTom22
Quick checks:
Checked that ground today and all was good. Pulled it and cleaned up some anyway. Still getting 12v to both wires at the injector plug. Currently in the middle of trying to get the ccm and the splice for the data line that's hidden back there to see if that is my issue. Can't pull codes anymore the info screen is no longer coming back on.
