Very strange problem
Old Oct 7, 2025 | 08:26 PM
Quentello's Avatar
Quentello
Default Very strange problem
Hi all, first post, (sorry, kinda long)
So about two years ago or longer I drove my Vette into the storage garage where I parked it for the winter. It sat til the next spring and when I went to drive her she fired up and I let her idle for a bit while I over looked everything, jumped in backed her out of the garage and sat there for a moment before putting her in gear.
She stalled out.
I tried to start her again but the only way she would start is with the throttle on the floor.
She ran ruff and would not idle without dyeing and had to floor her again and keep the RPM up. But as soon as you put her in gear she died again.
When you put her in gear it was like she was in forward and reverse at the same time. Would not go anywhere and still would not idle .
I pushed her back into the garage and went home. The next day I brought a friend incase I had to push her again.
Well she fired right up and I let her idle while we talked about what went on the day before. As soon as she got almost to running temp she died.
Back to the same problem. Starts but once almost warm dies of you need to keep her in high RPM`s but still stalls as soon as you put her in gear.
I have been chasing this problem for better then a year now with no results,, HELP
Old Oct 7, 2025 | 10:13 PM
CorvetteRules's Avatar
CorvetteRules
You need to pull any codes to hopefully point you in the right direction
Old Oct 7, 2025 | 10:24 PM
s carter's Avatar
s carter
Some base questions stick or auto
Have you cleaned the throttle plates, and your sure you're fuel isn't contaminated, stale or water (yes even garaged Pampered cars can get water in tanks)
Have you checked your fuel pressure.
Old Oct 8, 2025 | 09:26 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
As mentioned, check your fuel pressure, especially after it dies after getting warm.
Old Oct 8, 2025 | 09:34 AM
signify's Avatar
signify
So she goes in to closed loop meaning until the computer starts monitoring she runs fine. Sounds like coolant temperature sensor. How old is the gas smell it if it stinks pump it out.
Old Oct 8, 2025 | 03:18 PM
Quentello's Avatar
Quentello
Well, automatic trans, yes runs fine on open loop, shitty on closed,, changed the fuel ,, not bad smelling when i did that,, I use clear supreme (no Ethanol), changed coolant temperature sensor, fuel pressure is good, cleaned and checked throttle plates, brake light switch (someone said that could do it), Changed other sensors also,, .
Ran great when I parked her,,, Thought could be the EMC but that's a spendy part and dont want to just throw more parts and money at her, Have a new O2 sensor ready to go in when I fix the starting issue,,
To Very strange problem
