Opti problem
Old Feb 18, 2003 | 04:30 PM
Stingray1970's Avatar
Stingray1970
Default Opti problem
Need suggestions for 94. Runs ok cold, backfires as the engine heats up. Thinking moisture in the cap. What is this thing going to need to fix the problem. Opti net is $ 449.98 and cap and rotor kit is $ 253.07 Thanks in advance :steering:
Old Feb 18, 2003 | 04:52 PM
jimswhite92's Avatar
jimswhite92
Default Re: Opti problem (Stingray1970)
Found this in the tech tips. It is informative. Make sure you check with Jeff Koop before you make a purchase.
https://www.corvetteforum.com/techti...=174&TopicID=2
Old Feb 18, 2003 | 04:58 PM
JayH's Avatar
JayH
Exhaust leak? HO2 sensor problem??? Why are you supposing the opti?
Jay
Old Feb 18, 2003 | 05:30 PM
Stingray1970
Default Re: Opti problem (JayH)
Car has only 17,000 on it. Exhaust is quiet and doesn't appear to have any leaks. Never had an O2 cause backfiring. I was thinking moisture in the cap.
Gene
Old Feb 18, 2003 | 05:54 PM
JayH's Avatar
JayH
Well, you should be able to pick up the complete distributor assy for under $300 from Jeff Kopp, but I would have someone put the thing on a computer and check your o2 sensor operation (which only plays into the equation after the car warms up,) first.
just my $0.02,
Jay
Old Feb 19, 2003 | 04:50 PM
John Row's Avatar
John Row
An opti problem's symptom are ususally high RPM missing and irratic idle.
If you need one, check with Jeff Kopp at Superior Chev. It's about $330 for a complete unit.
https://www.superchevyperformance.com/
Or go with a complete billet opti with proper seals from Dyno Tech Engineering for $550.
http://www.dynotech-eng.com/dynaspark.htm
[Modified by John Row, 3:51 PM 2/19/2003]
Old Feb 19, 2003 | 04:57 PM
Black85L98's Avatar
Black85L98
I vote no on the Opti. Unless you have had the car through a few car washes with the hood up. Spend $30 to put it on a machine, not $300 on a Opti.
If you have more time than money you can try to clean it if the bearing is good. I had 100K plus on mine before I cleaned it and it is still going. :blueangel: On a prayer.
Later
Old Feb 19, 2003 | 05:00 PM
JayH's Avatar
JayH
Default Re: Opti problem (John Row)
:crazy:
Check this thread for some more info on the Dynaspark vs the opti from Jeff too.
Jay
To Opti problem
