Howling noise when turning
Old Feb 19, 2003 | 08:14 PM
scorned1's Avatar
scorned1
Default Howling noise when turning
I have a 96 CE LT4. It has started to make a howling noise when I make a turn. It sounds like it is coming from the rear end area. Any ideas? This has got me worried.
Thanks for any help/advice. :nonod: :nonod:
Old Feb 19, 2003 | 08:20 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Howling noise when turning (scorned1)
Does it make a difference if you are turning right or left?
I assume you have eliminated lackof PS Fluid as a problem
Jack
Old Feb 19, 2003 | 08:21 PM
Glasman66's Avatar
Glasman66
Wheel bearings?
Old Feb 19, 2003 | 08:31 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Howling noise when turning (Glasman66)
Wheel bearings?
:D :D That's why I asked if it made a difference which way he was turning :D :D
:steering: [ I love that Lil Guy! ]
[Modified by jackdaroofer, 8:32 PM 2/19/2003]
Old Feb 19, 2003 | 09:42 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
My '96 LT4 just started doing the same thing, but only when turning left at slow speed/small radius turns. At first I thought "rear wheel bearing", but the more I hear it, the more I'm thinking "differential". Hope one of youz guyz has experienced this and can steer the both of us in the right direction.
Larry
LT4coupe
:seeya
Old Feb 19, 2003 | 09:53 PM
vader86's Avatar
vader86
Default Re: Howling noise when turning (rocco16)
Could be something like bearings, U-joints, diff locking up.
Id bet its the bearings though.
Old Feb 19, 2003 | 09:58 PM
scorned1's Avatar
scorned1
Default Re: Howling noise when turning (jackdaroofer)
It happens turning both ways and usually when I make a sharper turn rather than a sweeping turn.
Old Feb 19, 2003 | 10:56 PM
vader86's Avatar
vader86
That sounds like a bearing, theyll howl if you turn the car sharply.
Old Feb 20, 2003 | 12:45 AM
Aggravated4life's Avatar
Aggravated4life
When my 86 did this,the rear end fluid needed to be changed.It sounded like a power steering howl around turns both left and right.Doing some figure 8's in a parking lot helped narrowed it down.New fluid and posi additive did the trick.Also,DO check the bearings as well.
Old Feb 20, 2003 | 05:00 AM
scorned1's Avatar
scorned1
Default Re: Howling noise when turning (Bill's86Coupe)
Thanks for all the advice. I will check the bearings and fluid level.
Old Feb 20, 2003 | 06:43 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
It would be very unusual and highly coincidental for both bearings to go bad at the same time.
I wouldn't just "check" the fluid, I would change it, including adding the "GM Diff additive". I just remembered a friend had a similar problem on a C3 a while back and changing the fluid and putting in new additive solved it.
Jack
Old Feb 27, 2003 | 07:20 PM
scorned1's Avatar
scorned1
I removed as much fluid as possible. Added one bottle of GM posi additive and filled it up with new oil and the howling is gone.
Thanks for the help. :cheers:
Old Feb 27, 2003 | 08:00 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: Glad to hear it! :thumbs: "Bills86 Coupe nailed it"!
[Modified by jackdaroofer, 8:03 PM 2/27/2003]
To Howling noise when turning
