Rebuilt L98 First Time Start Up EST Question
Old Jan 11, 2026 | 05:44 PM
solar88's Avatar
solar88
Default Rebuilt L98 First Time Start Up EST Question
I have rebuilt my L98 and it’s in the car and almost back together, it’s an every weekend project that started on Halloween and hope to fire it up in a couple weeks. When I go to fire it up for the first time, should I leave the EST connected or unconnected ? I have a lot of history with SBC and will have the timing “eyeballed” but was wondering how I should go about setting the timing on a brand new engine with EST ?
Old Jan 11, 2026 | 06:07 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I would have it disconnected from the first start. Get it warm and lock in timing.
Old Jan 11, 2026 | 06:41 PM
solar88's Avatar
solar88
Ok. First start disconnected, set timing, shut off engine, reconnect EST, disconnect battery for “ten minutes”, then all good ?
Old Jan 11, 2026 | 08:07 PM
AGENT 86's Avatar
AGENT 86
Yes, but 10 minutes to clear code is not necessary. 10 seconds should be good enough.
Old Jan 11, 2026 | 08:17 PM
solar88's Avatar
solar88
Thank you.
Old Jan 11, 2026 | 09:48 PM
IHBD's Avatar
IHBD
Pro Mechanic
You can get an electronic distributor within a degree or two. Closer than "by eye".
Once the distributor is installed for correct #1 TDC, install the cap and everything to make it run. Put the balancer marks on where you want to set the timing to. (At this point it doesn't matter if you are on #1 or #6, the marks work for both.) Turn the key to RUN. Twist the distributor cap CCW until you hear the coil fire and the fuel pump run. Turn it CW beyond where it fired, and go CCW again until it fires. Do this a few times to get a feel (literally) where the firing point is. I move it CCW just a smidgen more than the firing point. I'm usually within a degree when I check it with a ligh after its running.
You don't have to disconnect the EST bypass wire for static timing because EST doesn't become active until 400 RPM.
To Rebuilt L98 First Time Start Up EST Question
