wheels differences: design, width...backspace, offset..
Old Feb 20, 2003 | 12:28 PM
conv90's Avatar
conv90
Default wheels differences: design, width...backspace, offset..
I have a 1990 convertible with stock wheels. Rims are all 17” x 9.5”with 275/40/zr17.
Question 1 : All 4 wheels are the same regarding backspacing and offset?? Any difference from front to rear?
Question 2 :’90 ZR1 (with 11” rear) have the same “directional” design as my ‘regular 90 vette? (see my signature for reference )
Old Feb 20, 2003 | 03:38 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: wheels differences: design, width...backspace, offset.. (conv90)
yes, they are all the same, just directional, no difference otherwise
yes, they are the same, just wider with a 50mm offset to make them fit :D
Old Feb 20, 2003 | 03:58 PM
vader86's Avatar
vader86
your wheels are 17x9.5x56mm
ZR1 wheels are 17x11x50mm to fit under the bigger bumper.
Old Feb 20, 2003 | 05:11 PM
JasonL's Avatar
JasonL
Default Re: wheels differences: design, width...backspace, offset.. (vader86)
:nono:
ZR1 wheels have a 36mm offset.
Old Feb 20, 2003 | 05:42 PM
vader86's Avatar
vader86
Default Re: wheels differences: design, width...backspace, offset.. (JasonL)
oops, the Zr1 are 36mm for 17x11 and the Grand Sport was 50mm for the 17x11.
Old Feb 20, 2003 | 08:15 PM
ussopportune's Avatar
ussopportune
2nd Gear
How exactly do you measure the offset? I have a 1995 Coupe (non-ZR1) with A-Mold ZR1 5 spoke silver painted wheels. The fronts are 9.5" and the rears are 11". If I can find a pair just like the front, will they fit on the rear with no problem?
kevino1@prodigy.net
Old Feb 20, 2003 | 09:46 PM
ittlfly's Avatar
ittlfly
Default Re: wheels differences: design, width...backspace, offset.. (ussopportune)
your fronts should be a 56mm offset and they will fit on the back with the same off set as long as they are 9.5 x 17. Off set is measured from the wheel center line to the backside of the mounting surface (where the wheel mounts on to the studs.)
Old Feb 21, 2003 | 10:40 AM
conv90's Avatar
conv90
Ok, let me know if I understand….
All 4 wheels on my 90 are the same, same offset, same backspace and same width (…Yes I have 2 left an 2 right due to the symmetrical ‘rotational’ design).
11” rear wheels from a 90 ZR1 have the same design as my car.
……..So if I can buy a REAR set of a 90 ZR1 I can install 315 rear tires?
Then…
GS rear 11 rims comes with 50mm or 56 mm offset (don’t remember if it’s 50 or 56…) and ZR1 comes with 36mm offset.
From this I can deduce that ZR1 tires will ‘stick out’ from rear fenders more than a GS set and
a ZR1 set will be less prone to rub (from inner side..).
I’m right???
A GS fender extension will be sufficient to cover the tire?
Anybody with a rear set of a 90 ZR1 wheels on sitting down…..?
Old Feb 21, 2003 | 10:47 AM
mn_vette's Avatar
mn_vette
I’m right???
I believe it's the other way around, the GS wheels will stick out further than the ZR1 wheels. That's why the GS has fender flares, to cover that part that sticks out. The smaller offset pulls the wider rim inside the wheel well more.
Old Feb 21, 2003 | 10:58 AM
_freakmonkeydogboy_
:withstupid: yeah, my bad...
:nono: the zr-1 rims will stick out more because they have less of an offset. the zr-1's had a wider rear end which is why they didn't need fender flares, the GS needed flares because it's just a normal coupe body and the 50mm offset makes the wheels stick out about 1/4", the zr-1 rims will stick out more, like maybe 1/2-3/4" :D
[Modified by _freakmonkeydogboy_, 10:04 AM 2/21/2003]
Old Feb 21, 2003 | 11:26 AM
conv90's Avatar
conv90
Default Re: wheels differences: design, width...backspace, offset.. (_freakmonkeydogboy_)
...so I'm right...
..ZR1 wheels 'stick out' more than GS if isntalled on a stock '90.
Old Feb 21, 2003 | 11:42 AM
Raistlin's Avatar
Raistlin
...so I'm right...
correct
Old Feb 21, 2003 | 11:55 AM
Cruz 86's Avatar
Cruz 86
Default Re: wheels differences: design, width...backspace, offset.. (Raistlin)
I've got an 86. Is there an 11 inch w/315 tire combo made that won't stick out a little with out a GS flare? If so, which one? Otherwise I'll stick with 17x9.5 wheel.
Old Feb 21, 2003 | 12:49 PM
_freakmonkeydogboy_
Default Re: wheels differences: design, width...backspace, offset.. (Cruz 86)
you can get spacers and run the GS offset wheels and they will maybe stick out neglegebly...maybe 1/4", hwever you could try it without the spacers and they would sit in even more, but i don't know if that would rub anything inside or not... :D
Old Feb 21, 2003 | 01:00 PM
vader86's Avatar
vader86
Youll need the flares for 11" rears even with the 38mm offset. Spacers wont make any difference there. One reason why i'm gonna stick with 17x9.5 all around.
Old Feb 21, 2003 | 03:30 PM
conv90's Avatar
conv90
Anybody with a rear set of a 90 ZR1 wheels to sell…..? :rolleyes:
Old Feb 21, 2003 | 09:27 PM
USAZR1's Avatar
USAZR1
Check out the ZR-1 forum.
To wheels differences: design, width...backspace, offset..
