Ram Hydraulic clutch conversion question
Old Mar 2, 2026 | 02:45 PM
XLR8-R's Avatar
XLR8-R
Default Ram Hydraulic clutch conversion question
For those that have done it, would it be possible to stab the transmission already bolted to the bellhousing? Sorry if this is a dumb question but it seems like it would solve any issues getting the throw out bearing lined up correctly. Clutch lines would already be through the previous slave hole. I have the kit and will be installing soon.
Old Mar 9, 2026 | 09:24 AM
Gale Banks 80''s Avatar
Gale Banks 80'
I tried that and gave up. It might be possible outside the Car but not putting it together in the Trans Tunnel. It's not that big of a deal to do it. You can cut an inspection hole or use a camera to make sure it lined up right.
Old Mar 9, 2026 | 11:07 AM
XLR8-R's Avatar
XLR8-R
Ok, thank you for the reply.
Old Mar 14, 2026 | 07:27 AM
1993C4LT1's Avatar
1993C4LT1
I'll add, there is no need to do any drilling on the bell housing. Take your time measuring the TOB to be within specs of RAM. I honestly cannot remember if my dad and I installed the bell housing and trans at the same time. I'll ask him, and see if he remembers.
Old Mar 14, 2026 | 07:00 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I used long bolts to keep it aligned
If you have the dual disk, get the steel alignment tool
I could not get all the plates aligned with the plastic one.
A transmission jack was really helpful
Old Mar 14, 2026 | 09:02 PM
nb_destroyer's Avatar
nb_destroyer
I've done mine and need to post a write-up on it, tl;dr you cannot due to how the hydraulic lines are positioned. As 1993C4LT1 mentioned there's no need to drill into the bell housing if you're smooth with it, I recommend a borescope and a thin rod to poke around with to get it all lined up. Unfortunately I didn't have a scope on hand so I drilled mine for better access, but even if you do it's not the end of the world and made of magnesium, so very soft.
This is the thread from when I did it, with some more images from Brian and others.
Old Mar 15, 2026 | 11:05 PM
XLR8-R's Avatar
XLR8-R
Thanks for the replies. I completed mine, did not drill the bellhousing, used a camera. It was stressful but went in pretty easy. I was able to use the plastic alignment tool on my dual disc. So far I am very happy with the results. I also installed Core short shifter and am very happy with it as well. The clutch feels very nice considering it’s supposed to handle 700 plus horsepower.
Old Mar 16, 2026 | 12:08 PM
XLR8-R's Avatar
XLR8-R
I think my dual mass flywheel is toast? Replaced it with the Ram dual disc and steel flywheel as mentioned above. No more rattle when I shut the car off.
File Type: mov
Old Mar 17, 2026 | 10:46 AM
1993C4LT1's Avatar
1993C4LT1
Awesome, nice work and enjoy
To Ram Hydraulic clutch conversion question
