91 c4 base
Old Apr 6, 2026 | 09:05 AM
james big red's Avatar
james big red
6th Gear
Default 91 c4 base
Just purchased in January haven't really driven the car but I noticed oil just below distributor not sure if its seals or something else
Old Apr 6, 2026 | 12:55 PM
Bikespace's Avatar
Bikespace
The safest thing to do would be to sell your C4 immediately, and buy a C3 instead.
EDIT: Did this thread get moved to C4 Tech (from C3)? Well, I stand by my advice. And pictures always help!
Old Apr 6, 2026 | 01:45 PM
james big red
6th Gear
Not selling but I`ll take a c-3 too
Old Apr 6, 2026 | 04:15 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Hi, if it is at the base of the distributor where it sits on the manifold, yes there is a circular paper ring gasket. If its leaking from there it would odd for it to more than just a very very limited weep.
If the leak is below the distributor and drizzling down the back of the block then chances are that it is a failed “rear china wall” leak. Very VERY common but also very easy to rectify with tools and the patience to do the job.
Of note, other things in that vicinity that could leak oil:
- oil pressure sensor sending unit AND its threads into the blocks port.
- the rear intake manifold to block gasket.
Try posting a pic and we might be able to further help. Cheers.
Old Apr 6, 2026 | 11:46 PM
C4industries's Avatar
C4industries
- oil pressure sensor sending unit.
VERY common for these to leak. There's an oil pressure sending unit for the gauge and an oil pressure switch back there. The oil under these units is pressurized while the engine is running and they will leak internally. When they do, oil comes out through the electrical plug. Unplug each and if the plug is wet with oil, replace the unit.
Old Apr 7, 2026 | 08:23 AM
james big red
6th Gear
Thanks will try and post picture soon weather here in Michigan not cooperating at the moment.
Old Apr 7, 2026 | 08:24 AM
james big red
6th Gear
Thanks I will look into it
Old Apr 7, 2026 | 10:00 AM
CorvetteRules's Avatar
CorvetteRules
I had a leak from the oil sensor on the rear of block when I had a L98. Was fairly easy to replace.
Old Apr 7, 2026 | 10:14 AM
james big red
6th Gear
Originally Posted by corvetterules
i had a leak from the oil sensor on the rear of block when i had a l98. Was fairly easy to replace.
appreciate the help
To 91 c4 base
