DIACOM
Old Feb 26, 2003 | 05:29 PM
CT95ATLANTA's Avatar
CT95ATLANTA
Default DIACOM
Has anyone had problems with DIACOM recording the Pre Store Cache and not anything after that......or it seems that way when I pull a saved file up and try to graph it. I have Pre Store Cache information and it stops at time zero. I have the Record Length set at 8000, Display Rate of Fast and the Mode as Normal.
Old Feb 27, 2003 | 01:30 AM
HighHopes85's Avatar
HighHopes85
Default Re: DIACOM (CT95ATLANTA)
Hit the spacebar.
Old Feb 27, 2003 | 09:40 AM
CT95ATLANTA
Default Re: DIACOM (HighHopes85)
Thanks, I first thought maybe the space bar was sticking but it wouldn't ever pick up the Pre Cache if it wasn't getting a proper signal from the space bar. This is very frustrating!!!
Old Feb 27, 2003 | 12:34 PM
B84RADR's Avatar
B84RADR
DIACOM is what you guys are using to read the data from your ALDL port, right?
Old Feb 27, 2003 | 02:03 PM
HighHopes85
This is not 100% correct.
I gave my laptop to a buddy so he could use it on his car. A week later, I asked what the data runs looked like. He said "It isn't working. Only the values before 0 frames got stored".
I asked him if he knew he had to trigger the recording. He said no.
If you are linked and you just go to save, it will only save what is before frame 0. The bottom line on the screen will change...from something like "DIACOM Linked" to "Retreving data".
Old Mar 3, 2003 | 08:43 AM
CT95ATLANTA
Thanks for your help, you were right, I wasn't recording.......I have to hold the space bar until it beeps and then it starts recording.....I made a couple of WOT runs this weekend to the rev limiter at 6200 RPM's but the recordings showed me shifting at around 4000 RPM's so I'm now questioning the recording accuracy/updating frequency.
Old Mar 8, 2003 | 09:52 PM
best_vette_yet's Avatar
best_vette_yet
My Diacom won't read a 95 vette data stream. I even made an adaptor to go from the obdII to obdI so I could hook up. Still nothing. I know the adaptor worked because my autoxray scanner would link perfectly with the home made adaptor. How are you hooking in to the 16 pin OBDII connector? :confused:
Old Mar 10, 2003 | 01:27 PM
CT95ATLANTA
Default Re: DIACOM (best_vette_yet)
I got a connecter from the guy I bought DIACOM from. One end hooks into the long cord that comes with the software and the other end has 3 wires that goes into #'s 5, 6, and 9 in the plugin.
Old Mar 10, 2003 | 09:05 PM
drive it's Avatar
drive it
Just call diacom-they'll give you that cable adaptor for the 95s for free!
Old Mar 10, 2003 | 09:32 PM
best_vette_yet
Default Re: DIACOM (drive it)
Thanks, I'll give it a try.
Old Mar 11, 2003 | 09:27 AM
CT95ATLANTA
Does anyone know why my readings seem like only brief snapshots rather a true multi-second data stream? The main reason I bought the software is to make sure there were no KR signals......which there are not so I'm happy, but now I would like nice pretty graphs that show everything that happens to the rev limiter.......also how do you see the settings for the fans? The info screen only shows on or off settings and then a brief description of what it is. I want to see the true tables with 0's and 1's. Should I have got LT1Edit?
Old Mar 11, 2003 | 01:11 PM
HighHopes85
Should have at least 6 frames/second. You might need to select a faster refresh rate.
Diacom only has provisions for graphing 3 items at one in brush recorder/strip chart style.
Diacom only shows i/o stuff. It doesn't show programmed variables (except for RPOM ID, etc). So yes, LT1Edit is probably what you were after.
Old Mar 11, 2003 | 01:33 PM
CT95ATLANTA
Thanks, I'll look at the refresh rate tonight and also start looking for LT1Edit somewhere for sale.
Old Mar 12, 2003 | 12:02 AM
drive it's Avatar
drive it
If you're looking for editing software-check out tunercat-they have tdf for 95 for a lot less than lt1edit....and great support!
Old Mar 12, 2003 | 12:44 AM
HighHopes85
I think that LT1 edit is a complete package...both scanning and tuning. TunerCat is just tuning. If you go with TunerCat, you will still need Diacom. If you go with LT1 Edit, I don't think you will need Diacom. Hope that makes sense.
Old Mar 12, 2003 | 12:17 PM
CT95ATLANTA
Thanks, I found the LT1 Edit at carputing.com for $150 for the Standard package and $200 for the Expert. Which one would you suggest?
To DIACOM
