Can a MAP sensor output be split?
Old Feb 28, 2003 | 10:55 AM
steveelsbury's Avatar
steveelsbury
Default Can a MAP sensor output be split?
I have a 3-bar MAP sensor fitted and connected to my FAST. My boost is currently maxing out at 12 lbs, so I only need a two-bar. I didn't think this matterred until I discovered that a MAP sensor has a fixed voltage range, so using it to measure 3 bar instead of 2 gives less signal resolution. It also means there the top third of my fuel map in the FAST is a waste of time, as the engine will never go there!
OK - I also have a 2-bar sensor which drives the water injection. Can I simply split the signal from this and connect it to the fast as well, or will the altered impedance mess up the signal.
I'm betting one of you guys will know the answer to this one....if not, I'll just have to buy another 2-bar sensor!
Thanks,Steve
Old Mar 1, 2003 | 09:50 AM
ELEVENS's Avatar
ELEVENS
Default Re: Can a MAP sensor output be split? (steveelsbury)
Don't know about your app, but when I used to run a Haltech E6GM and factory computer at the same time, I could "split" the outpout from the MAP no problem. Neither computer objected or read incorrectly.
Good luck,
-Bill
:cheers:
Old Mar 1, 2003 | 07:48 PM
dgoodhue's Avatar
dgoodhue
The signal can be split to your ECM. The only problem you would have splitting a MAP signal is if the split loaded down the circuit too much, but this isn't the case with an ECM input.
Old Mar 12, 2003 | 09:19 AM
black bart's Avatar
black bart
Default Re: Can a MAP sensor output be split? (dgoodhue)
Well I have the same problem. I was thinking about installing two map sensors also but was going to run the output from the map sensor to the ecm through a relay use either the ecm or a rpm switch to trigger the relay.
With the relay in one position the ecm will read from the 2 bar when the relay is in the other position the ecm will read the 3 bar. I think for me a rpm switch would work because if I turn enough rpm to exceed 15 lbs. of boost I"m at wot anyway. If you are not at wot then no need to turn rpms that high so about all the three bar would control would be wot at high rpm.
:banghead:
Old Apr 4, 2003 | 10:38 PM
tjwong's Avatar
tjwong
Yes, you can split or should I say "share" the MAP sensor output to both devices. The main thing to do is to make sure that the grounds for both systems are at the same potential. Easily done by connecting the ground for both systems at the same point.
To Can a MAP sensor output be split?
