Twisted Half Shaft????
Old Mar 3, 2003 | 08:26 PM
WHRITZY's Avatar
WHRITZY
Default Twisted Half Shaft????
Just took my 90 to wheel place and had new wheels installed. While speed balancing the drivers side rear wheel, the guy had problems as the wheel would not balance and appeared to be jumping around pretty good. He took wheel off, put a couple of lug nuts on hub, and we ran car again. The half shaft appeared to be out of balance/bent/twisted, whatever...I could see it moving up and down as it rotated and the brake disc was moving in the caliper......I take it I have a bent half shaft.....how, I don't know. This car has 26k on it, and it's been down the drag strip maybe 10 times in its life....oh yeah, when I drive it, I don't feel a thing! You'd think I could feel something as much as I could see the thing not rotating smoothly.....does anyone have any experience with this?
Thanks! :confused:
Old Mar 3, 2003 | 08:34 PM
scorp508's Avatar
scorp508
Default Re: Twisted Half Shaft???? (WHRITZY)
Ahh yes the good ole' torque L98 snaps another. :thumbs: Seriously though, it doesn't take all that much to twist one of these if you catch it juuuust right. Replacements aren't all that expensive and are easily installed. :)
Old Mar 3, 2003 | 08:37 PM
ethan1321's Avatar
ethan1321
Sounds strange. Did the tire shop have the car supported by the suspension? If the suspension was allowed to sag this can put the hub and rear end so far out of alignment that the hub would have to move up for the half shaft to complete one revolution. Giving the illusion that the shaft is bent.
Hope this helps.
Old Mar 3, 2003 | 09:04 PM
WHRITZY's Avatar
WHRITZY
As a matter of fact, Ethan, they lowered the car while it was on the lift onto two things that appeared to me to be sophisticated jack stands....thereby, in my opinion, supporting the rear end of the car by the suspension. The passengers side rear did not have the problem...possibly he had the drivers side stand misplaced?
Old Mar 3, 2003 | 09:07 PM
scorp508's Avatar
scorp508
Ok ..... hold a straight edge on the side of the halfshaft as you turn the wheel. Also measure from end weld to end weld in a few places to see if you get the same measurements all around.
Old Mar 3, 2003 | 09:13 PM
WHRITZY's Avatar
WHRITZY
Thanks for the help, Scorp....I'll give it a shot in the am...btw, any good places to buy the 1/2 shaft and, should it need it, should I buy all accompanying parts., i.e. new universals, etc?
Old Mar 3, 2003 | 09:48 PM
ittlfly's Avatar
ittlfly
QUOTE]Thanks for the help, Scorp....I'll give it a shot in the am...btw, any good places to buy the 1/2 shaft and, should it need it, should I buy all accompanying parts., i.e. new universals, etc?[/QUOTE]
Give Jeff Koop a call. Be sure to tell him you are a forum member.
Old Mar 3, 2003 | 09:57 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
A good idea for everyone is to paint lines along the length of the shafts.
When you see the lines twisting then you know the shaft is twisting and then you know when it's time to replace.
The halfshafts will usually go first, that's the way the car was designed anyway.
Old Mar 3, 2003 | 10:01 PM
WHRITZY's Avatar
WHRITZY
Thanks, fellas. Anyone have a number or e mail for Jeff Koop? Also, is this a relatively easy job for a 1/2 azzzed mechanic with normal tools?
Old Mar 3, 2003 | 10:07 PM
Mr Mojo's Avatar
Mr Mojo
Jeff Kopp-Superior Chevrolet 1-800-728-8267
Old Mar 3, 2003 | 10:09 PM
WHRITZY's Avatar
WHRITZY
Thanks, Mojo.
Old Mar 3, 2003 | 11:21 PM
JCAIRE2's Avatar
JCAIRE2
Check out their site here: http://www.superchevyperformance.com/about.html
They have a discussion forum moderated by Jeff also:)
To Twisted Half Shaft????
