Nitrous switch question
Old Mar 5, 2003 | 08:51 PM
VetteNoob's Avatar
VetteNoob
Default Nitrous switch question
Is there such a switch for nitrous that will allow for speed consideration as well as a WOT throttle switch? The reason I ask is because I would like for the nitrous to be able to engage under WOT after 30 mph.
Is there any reason this would be a bad thing to want to do? Does this type of switch exist? Im thinking about giving the L98 a little boost, but it spins tires enough as it is off the line so my thinking is to get the added help once the vette is rolling.
Any info would be appreciated.
Old Mar 5, 2003 | 09:14 PM
95AquaC4's Avatar
95AquaC4
Default Re: Nitrous switch question (VetteNoob)
Technically,such a thing does exist. It's called a progressive controller. It doesnt work with RPM or MPH, but simply with seconds. Delay as many seconds as you feel you need. Trial and error. You can customize it to your needs. Adjust it low, and adjust to come in full when already rolling good. This will eliminate nitrous spin.
[Modified by 95AquaC4, 9:21 PM 3/5/2003]
Old Mar 6, 2003 | 01:55 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Nitrous switch question (95AquaC4)
The only RPM specific controller is the Mastermind but it is garbage. All of the othe ones that I know of are time based as Aqua said. I have never seen one that was speed dependent though.
Old Mar 6, 2003 | 02:12 PM
VetteNoob's Avatar
VetteNoob
Default Re:
Has anyone every tried to convert a RPM switch to obtain the signal from the ECM speedo? Only thing about the timed switches that I dont like is the already rolling WOT situations. Could the delay switches be enabled and disabled on the fly?
To Nitrous switch question
