LT1 To LT4 Conversion???
Old Mar 7, 2003 | 11:30 AM
Kizmo's Avatar
Kizmo
Default LT1 To LT4 Conversion???
Has anyone on the forum ever purchased and installed the LT1 to LT4 conversion kit from GM performance? If so I would like to know the diffulculty of the install and also what the performance gains you achived were, if any. Also was it worth the $$$$$.
Thanks. :steering:
Old Mar 7, 2003 | 12:39 PM
vader86's Avatar
vader86
Default Re: LT1 To LT4 Conversion??? (Kizmo)
You dont need that stuff.
Just port your intake manifold, port your heads, and add a hotcam kit, and youll be alot faster than any LT4.
Old Mar 7, 2003 | 01:03 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: LT1 To LT4 Conversion??? (vader86)
:withstupid:
Old Mar 7, 2003 | 01:42 PM
Rick93Z07's Avatar
Rick93Z07
Porting an LT1 intake is a total waste of time. A professional intake port job adds 3-5 HP to a built 435 HP LT1 setup. Headers, cam, head porting and oversize valves, matched chip and 52mm TB will give 425HP with long tubes or 400 HP with EPA shorties. Run with 405 HP Z06's. Skip the 335HP LT4 upgrade.
Old Mar 7, 2003 | 02:38 PM
Kizmo's Avatar
Kizmo
Default Re: LT1 To LT4 Conversion??? (Rick93Z07)
What type cost are we talking about with the above mentioned mods???
Old Mar 7, 2003 | 02:39 PM
SHiNoBi LT4's Avatar
SHiNoBi LT4
Simply not worth it.. unless.. you are looking to extract MAXIMUM power from the motor, ie. a NA stroker motor.
Old Mar 7, 2003 | 03:58 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
probably $5000 to $7000 if you have a shop do all the work......
top end "kits"go for $3000 to $4000 for parts alone.
here is a link to VETTE DOCTORS..(see left column)...
most packages of this type are priced simarlarly
http://www.thevettedoctors.com/htdocs/c4-rx.shtml
Old Mar 7, 2003 | 07:04 PM
95Redsled's Avatar
95Redsled
Thanks. :steering:
Ok, most here are not recommending this as is, but what if you had the LT4 intake and heads ported as well? I ask this because Pete at CNC has told me that by doing this I will see large gains over simply porting my LT1 heads. He did agree that porting an LT1 intake is a waste of time. So what kind of gains can we expect comparing ported LT1 heads w/ Hotcam to the LT4 conversion kit with ported heads and intake on a LT1? :boxing
Old Mar 8, 2003 | 05:46 PM
Kizmo's Avatar
Kizmo
Default Re: LT1 To LT4 Conversion??? (Phil-tha-Rush)
I can get the entire LT1 - LT4 conversion kit with all the parts needed, minus the timing chain for $2,000.00 from GM performance, ready to fit. Compared to this it seems like everything else is a rip off.
Old Mar 8, 2003 | 06:19 PM
SHiNoBi LT4
To put those heads and intake 9assuming thats with the LT4 roller rockers too) you will definitely see a gain. But in my opinion not worth $2000. Id guess maybe around 20 -25 hp. The LT4 cam was revised to take advantage of the better flowing heads too. If you are planning to do some serious modifications in the future ie. Ported heads/cam/stroker/etc, then go with the LT4s, they flow considerably better than the Lt1s when race ported. What you are probably comparing the LT4 conversion too is a heads/cam poackage. Remember a heads and cam package gives you many more options as to how much power you want. Although it is more expensive, you can gain an easy 50-100 hp and even more depending on how aggresive of a cam and porting job is done. :cheers:
Old Mar 8, 2003 | 06:29 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
425 HP :eek: :eek:
Flywheel or rear wheel?????????
WOW , I've only got 360 RWHP,
I must have missed something. :confused:
Old Mar 8, 2003 | 06:51 PM
SHiNoBi LT4
Default Re: LT1 To LT4 Conversion??? (mackeyred96)
seems hes talking flywheel... he said 405 for the z06, which is fywheel. Only 360 rwhp? u making fun of us? :) :lol:
To LT1 To LT4 Conversion???
