Those w/ TPIS Headers
Old Mar 10, 2003 | 02:07 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Those w/ TPIS Headers
Which header bolts are you guys using?
I have the stage 8 locking but they are much to short for the TPIS headers
Old Mar 10, 2003 | 03:05 PM
VetteNoob's Avatar
VetteNoob
Default Re: Those w/ TPIS Headers (Ruby6spd)
Stock bolts. You can go to any hardware store and get new Grade bolts.
Old Mar 10, 2003 | 03:24 PM
Ruby6spd's Avatar
Ruby6spd
Default Re: Those w/ TPIS Headers (VetteNoob)
I was hoping to use the locking bolts, but it looks like there arn't any options besides the stock length...
I guess I will be making sure they are tight every so often
Old Mar 10, 2003 | 03:29 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Used stock bolts.... :yesnod: :chevy
Old Mar 10, 2003 | 05:21 PM
cprgmr's Avatar
cprgmr
I haven't installed mine yet, but doesn't ARP make header bolts for this application?
Old Mar 10, 2003 | 05:32 PM
AS84's Avatar
AS84
Default Re: Those w/ TPIS Headers (cprgmr)
stock bolts here. They work just fine...make sure you re torque them after a heat cycle.
Old Mar 10, 2003 | 06:04 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Those w/ TPIS Headers (AS84)
I went to a local bolt distributer with my stock bolts and purchased allen socket bolts of the same grade and length. I did not like the clearance between the bolt heads and headers on cylinders 3 through 6. Now I can torque them properly without worrying about stripping them.
[Modified by 85vet, 6:05 PM 3/10/2003]
Old Mar 10, 2003 | 08:04 PM
chucks88's Avatar
chucks88
Default Re: Those w/ TPIS Headers (85vet)
Stock bolts here :yesnod:
Old Mar 10, 2003 | 11:37 PM
ciscokid's Avatar
ciscokid
I also used the stock bolts with no problems. A couple of them on the right bank were a little snug against the header tubes but all in all the stock bolts will get the job done.
Old Mar 11, 2003 | 07:59 AM
UDLUV12's Avatar
UDLUV12
I use ARP (12 point).
Old Mar 11, 2003 | 09:10 AM
Ruby6spd's Avatar
Ruby6spd
I think i am going to try to do the same. The clearance on the tube for cylinder 8 is tight, not to mention getting a socket back there!!
Old Mar 11, 2003 | 01:31 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Stock bolts. :thumbs:
Old Mar 11, 2003 | 05:40 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Those w/ TPIS Headers (Dominic Sorresso)
ME TOO :thumbs:
Old Mar 11, 2003 | 08:12 PM
h rocks's Avatar
h rocks
After "modifying" box wrenches etc., I finally came across the 1" ARP SS header flange bolts with a smaller hex head. These allowed me to use the thick Cometic gaskets. You can use a 1/4" drive socket set and not have to either "modify" your new headers, or fight with the last bolt on #8. What a B*&^% getting that from underneath after removing the "K" member, and turning it one flat at a time with a bastardized box wrench. As far as 12 points on an L98, forget it! It can be done, but what a MAJOR PITA on some of them.
To Those w/ TPIS Headers
