Removed Front Spring Today!!
Old Mar 11, 2003 | 09:45 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Removed Front Spring Today!!
After work i contiued my lowering project. Yesterday i jacked it up and removed the wheels so when i got home i could get right at it. After an hour and a half i had the spring out and had a look at it. How can these aftermarket lowering kits say you get a one inch drop when the spring isolator is only one inch thick!!!!! I don't have one of these so i am fabing up what i need. One of my ideas is to cut the rubber into the shape of those wedges. I am going to make a simple jig to asure uniform shape and protect the spring..What ever i remove i will cut out of the bracket and mig weld it back together. What do you guys think about this? Do i need that aluminium shim in there? I'll post tommorows progress aswell!!! Once again how the hell do these manufactures do their math when it comes to those #$#$#%^&^%$% wedges?????????? :confused: :banghead: :cheers:
Old Mar 11, 2003 | 11:42 PM
AGENT 86's Avatar
AGENT 86
Default Re: Removed Front Spring Today!! (AGENT 86)
:sleep: :sleep: :sleep:
