starting
Old Mar 12, 2003 | 02:28 PM
aldo802's Avatar
aldo802
Default starting
I went to start my vette and no good!! Checked all fuses battery is good, vats, I have a by-pass but I turn the the key and nothing! Maybe a starter?? or something going to starter??? :confused: [IMG][/IMG]
Old Mar 13, 2003 | 12:41 PM
jfb's Avatar
jfb
Default Re: starting (aldo802)
A bypassed VATS will keep the start enable relay closed, BUT you still have to go through the clutch safety switch (gear selector sw if you have an automatic) to get to the starter solenoid. Jump the clutch sw or if auto, jiggle the gear selector while trying to crank. You may have to remove the console cover to jump the gear selector switch.
I advise you to fix your VATS problem (probably worn out ign sw) because 99% of thefts are done by bashing your column and jumping the ignition.
[Modified by jfb, 11:41 AM 3/13/2003]
Old Mar 13, 2003 | 01:53 PM
aldo802's Avatar
aldo802
Default Re: starting (jfb)
Ok, I can try that because mine is an automatic! Just go back and forth with the stick?? :confused:
Old Mar 13, 2003 | 02:33 PM
aldo802's Avatar
aldo802
What does the switch look like?? I was just out going up and down sideways and still nothing! I didn't remove the consol yet though!!! It acts like I don't even have a battery in it! But that works real good! It's an interstate!!! :banghead:
Old Mar 13, 2003 | 04:33 PM
Steel Blue 91's Avatar
Steel Blue 91
Do you have any lights (exterior or DIC)? Any noises when you hit the key?
Old Mar 13, 2003 | 09:26 PM
aldo802's Avatar
aldo802
Default Re: starting (Steel Blue 91)
Yep and all my lights r bright!!! But no noice when I turn the key!!! It's like there isn't a battery in it! :confused:
Old Mar 14, 2003 | 01:02 PM
jfb's Avatar
jfb
You clearly have no 12v from the start position in the ign sw getting to the solenoid terminal on the starter. The gear selector switch can be seen after you remove the console plate over the gear shift lever. You can even jump 12v on the wire from the selector switch going to the starter to make the starter run. If no starter cranking, then I would remove the starter and have it checked.
Old Mar 14, 2003 | 06:13 PM
86Moon's Avatar
86Moon
I would double check the VATS bypass. If it's anything like mine, the connection seemed less than reliable initially. I just put my hush panel back on after a month. If my car exhiits the same symptoms again that's the first place I'm goin' :smash:
Old Mar 15, 2003 | 04:48 PM
aldo802's Avatar
aldo802
Default Re: starting (86Moon)
Tomarrow I will check it out, I have to pull the bottom dash plate off!!! I's sure sounds like something like that!! [IMG][/IMG] :rolleyes:
Old Mar 16, 2003 | 10:16 AM
aldo802's Avatar
aldo802
I stuck my arm through the engine department neat the head and exhaust pipe and felt the starter the front nut was lose! I don't if that is my promlem but I know I shouldn't have lose nuts! I have to get it jacked up to look at it and put a meter on the starter!!! :cuss
Old Mar 16, 2003 | 10:25 AM
jfb's Avatar
jfb
Remove the ground cable on your battery first, then tighten the nut on the electrical connector on your starter. This will prevent shorting the battery with your wrench when tightening the starter nut.
Old Mar 16, 2003 | 07:54 PM
aldo802's Avatar
aldo802
Will do tomarrow!@! i got it jacked up right now and jack stands underneath each axle!! Man I would hate to c that fall on me!!! Thanx for the advice. :cheers:
Old Mar 18, 2003 | 04:49 AM
aldo802's Avatar
aldo802
Well got her running again!!! It was the starter nut!!! Crawled underneath her and tighten it down and she kicked right over!!! Then I gave her a nice bath!!! Looking good again!! Now waiting for the snow and salt to go away!!!! :flag
Old Mar 18, 2003 | 04:53 AM
aldo802's Avatar
aldo802
My back bumper looked like URS before I put on a ZR-1!! Boy it changes the whole looks!! And I didget my car started today!! i twas a lose starter nut!! Gave her a bath and lookin good again!!
To starting
