Car won't start....help please.
Old Mar 17, 2003 | 09:02 AM
rats87's Avatar
rats87
Default Car won't start....help please.
My '87 has been out of inspection since October when it failed due to not having a catalytic converter. That was a nice surprise because I just bought it the prior May.
Anyway I finally decided to put one on this Saturday. First of all I do not know how to connect the small pipe that comes out the side of my cat. The cat has a crimped fitting on the end of it so I figured maybe I could just ignore it. :rolleyes:
After I put the cat on (ignoring the little tube thing) and jumped the car because the battery was dead the car ran fine. I let it run for about a half hour and then took it for a 15 minute drive to charge the battery.
The next day when I went to start the car it does not start. This time it does not seem like a dead battery. It sounds more like it is out of gas.
The trouble panel on the dash has the battery symbol lit up but I think that is always lit right? Also my battery voltage on the dash is reading about 11.
Does anyone have any ideas for me?
Old Mar 17, 2003 | 09:07 AM
sumoboy's Avatar
sumoboy
Default Re: Car won't start....help please. (rats87)
turn the key on and see if your getting fuel pressure.
Old Mar 17, 2003 | 09:11 AM
don hall's Avatar
don hall
You need to be more specific. Does the vette turn over, but not start?
The lighted batt. symbol signifies that the batt. is in a discharge mode.
Old Mar 17, 2003 | 09:13 AM
rats87's Avatar
rats87
Default Re: Car won't start....help please. (sumoboy)
I apologize for my ignorance but what am I looking for. :confused:
Old Mar 17, 2003 | 09:15 AM
rats87's Avatar
rats87
Default Re: Car won't start....help please. (Oldman)
The first time I tried to start it the day after installing the cat it almost started.
Now all it does is crank. Does that help?
Old Mar 17, 2003 | 09:16 AM
ZylaRace's Avatar
ZylaRace
W the engine not running, and the key in the ON postion, the battery symbol should be lit.
Are you sure VATS is not getting in your way?
Old Mar 17, 2003 | 09:22 AM
don hall's Avatar
don hall
..Now all it does is crank. Does that help?...
Yes. It tells us that you have juice. At 11 volts you are on the low side, but you obviously have enough juice to crank the engine. If you are out of fuel, that is an easy fix. Do you know how to access any DTCs (trouble codes)?
Old Mar 17, 2003 | 09:27 AM
rats87's Avatar
rats87
Default Re: Car won't start....help please. (ZylaRace)
VATS is Vehicle Anti-thft System right? What could be the problem with that?
Old Mar 17, 2003 | 09:29 AM
ZylaRace's Avatar
ZylaRace
If VATs was getting in your way, the engine wouldn't even crank.
Your problem is typically spark or fuel.
rats87's Avatar
rats87
I have a full tank of gas so thats not it. :D
No... I have no idea how to access the DTCs.
Old Mar 17, 2003 | 09:31 AM
sumoboy's Avatar
sumoboy
There should be a schrader valve(looks like a valve stem tip on your tires) Turn the key on and push it in like letting air out of a tire and see if fuel comes out. This is only an eyeball test. Better yet just get 5 gal of gas and put it in the tank. BTW is your fuel gauge reading anything?
VATS is on your ignition key...it's a small black oval shaped piece on the ignition key with a metal line through it.
Old Mar 17, 2003 | 09:33 AM
don hall's Avatar
don hall
This will explain trouble codes, how to access them, and remedies...
http://www.c4vettes.com/ecm.htm
Old Mar 17, 2003 | 09:37 AM
rats87's Avatar
rats87
Sumoboy thanks I will try that tonight.
Also sombody mentioned to me that I may need to disconnect my battery for 5 minutes and then reconnect to reset my ECU? Does this sound possible?
Old Mar 17, 2003 | 09:38 AM
ZylaRace's Avatar
ZylaRace
The fuel/schrader valve test,... keep your face away from it when you are pressing the valve. Face full of gas is not a good thing. :crazy: The fuel should be under 40+psi.
Your schrader vavle is on the pass side fuel rail, just in front of the distrib.
Old Mar 17, 2003 | 09:42 AM
ZylaRace's Avatar
ZylaRace
Disconnect the battery,... yeah that will clear your DTC's, but I put $ on this not solving your problem.
U either guts fuel or not. U either guts spark or not.
Pull a plug, see if it is wet. Pull a wire & crank it, do you get spark?
Old Mar 17, 2003 | 10:01 AM
rats87's Avatar
rats87
Thank you all. Now I have plenty of ideas to try when I get home tonight.
Old Mar 17, 2003 | 10:18 AM
sumoboy's Avatar
sumoboy
Forgot about the face thing. :eek: thanks
To Car won't start....help please.
Old Mar 17, 2003 | 10:20 AM
sumoboy's Avatar
sumoboy
Check this page also...it has some good info on evrything C4
https://www.corvetteforum.com/techti....php?TopicID=2
Old Mar 17, 2003 | 04:53 PM
Red ZEE06's Avatar
Red ZEE06
You need to charge the battery overnite and then diagnose the fuel pump. Sounds similar to a problem I had with my 91 (except for the cats) and it turned out to be the fuel pump. (only 48,000 mi's)
There are some good posts on the site for diagnosiong the fuel pump, after you confirm weather or not you have spark!
Old Mar 19, 2003 | 11:45 AM
rats87's Avatar
rats87
Default Re: Car won't start....help please. (Red ZEE06)
Interestingly, last night when I went out to try all of the suggestions you guys mentioned the car started right up. I tried starting 4 times and absolutly no problems. Now I am in a worse position because I do not know if I can trust it. :confused:
Any ideas?
Thank you all for your help.
