pulling engine on a 85
Mar 17, 2003 | 10:14 AM
hello,can someone tell me if I can pull the tranny with the engine at the same time,its an auto trans........thanks
Mar 17, 2003 | 10:18 AM
Re: pulling engine on a 85 (gerry85)
Yes but you must remove the hood.
Mar 17, 2003 | 10:34 AM
Re: pulling engine on a 85 (bubbaray)
thanks for the answer,I did a search here before I posted and didnt find much, what I did fiind was that all seemed to be leavin the tranny in the car.
Mar 17, 2003 | 10:48 AM
I have my 85 engine all disconnected and will pull the motor this weekend with the hood on.
Mar 17, 2003 | 10:56 AM
I removed my engine with the hood on and had plenty of clearence. Not sure if that would be possible with tranny attached still.
Mar 17, 2003 | 10:57 AM
Re: pulling engine on a 85 (ld85)
Yes I pulled my engine (by itself) with the hood on, but to get both out the hood will have to come off. Unless your a good Hudini.
Mar 17, 2003 | 03:34 PM
I pulled my engine and trans togther with the hood on. I had to because I couldnt separate my headers from the Y-pipe. All you need to do is put the back of the car up on jack stands or ramp and use an engine leveler. I bought mine from Pep Boys years ago. There nice to have even if you dont pull the trans because with the leveller you can set the angle of the engine so it lines straight up with the trans and the mounts during installs
Mar 17, 2003 | 03:52 PM
I have had my engine out several times, I always pull the tranny out still hooked up. :cheers:
Mar 17, 2003 | 03:55 PM
Re: pulling engine on a 85 (atotalnincompoop)
With the hood on? That would be nice cause the bell housinbolts are a &*!^@$% to get to!
[Modified by ld85, 3:56 PM 3/17/2003]
