Brake Bias Spring
Old Mar 22, 2003 | 04:43 PM
jstkrsn's Avatar
jstkrsn
Default Brake Bias Spring
I am in the middle of upgrading my brakes to J55's with drilled/slotted rotors. I've been told I that while I am at it I should put in a bias spring in the master cylinder. I've read that this shortens your stopping distances by 20 feet. Course they don't tell from what speed. Has anyone done this, is it worthwhile. Does it put more braking to the rear or to the front? Has anyone tried one of those adjustable proportioning valves? thanks for your responses.
Jim
Old Mar 22, 2003 | 04:55 PM
Rob90's Avatar
Rob90
Default Re: Brake Bias Spring (jstkrsn)
I have the spring and it helped. How much of it was the spring I could not tell ya because I did the spring the same time I did a rotor upgrade and started using a more Aggressive pad. Overall I think the braking is more balanced due to the increased rear bias. If you buy it get it from Doug Rippie for 13 bucks.
http://www.dougrippie.com/
Old Mar 22, 2003 | 05:13 PM
black bart's Avatar
black bart
Default Re: Brake Bias Spring (Rob90)
I like mine be sure to get it through DRM places like ecklers buy it from drm and sell it for three times what you can buy it for. :mad
Old Mar 22, 2003 | 05:14 PM
Raistlin's Avatar
Raistlin
How difficult was the install?
Old Mar 22, 2003 | 05:41 PM
Rob90's Avatar
Rob90
Default Re: Brake Bias Spring (Raistlin)
It was not bad at all. One of the easier mods I have done to the Vete. Here is a link to an old thread with some tec hints an overall evaluation of the spring.
http://forums.corvetteforum.com/zerothread?id=466741
[Modified by Rob90, 4:42 PM 3/22/2003]
Old Mar 22, 2003 | 05:52 PM
Raistlin's Avatar
Raistlin
Thank you Rob!! That thread answered all my questions. I'll be ordering mine shortly! :cheers:
Old Mar 24, 2003 | 09:19 PM
jstkrsn's Avatar
jstkrsn
Thanks for the advice guys, I'll be adding that to my list of things with this upgrade.
To Brake Bias Spring
