oil in engine coolant
Old Apr 3, 2003 | 05:03 PM
uralman's Avatar
uralman
Default oil in engine coolant
i have a 87 coupe. i have noticed quite a bit of oil sludge in the radiator overflow.
havent noticed coolant in the oil yet.
any ideas
Paul
Old Apr 3, 2003 | 05:04 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: oil in engine coolant (uralman)
Blown head gasket.
Old Apr 3, 2003 | 05:06 PM
uralman's Avatar
uralman
Default Re: oil in engine coolant (Lone Ranger)
shouldnt i see coolant in the oil?
Paul
Old Apr 3, 2003 | 05:13 PM
vader86's Avatar
vader86
Blown head gasket.
If oil is in the coolant, then coolant must be in the oil.
neverendingproject's Avatar
neverendingproject
id be looking at the oil cooler.. and it is possible that there would be no coolant in the oil if its bad. 50 or so psi oil pressure will easily overcome less than 20 psi in the cooling system.
Old Apr 3, 2003 | 05:15 PM
neverendingproject
Default Re: oil in engine coolant (neverendingproject)
but , its possible that your only seeing stop leak in the resevoir... ( gm suplemental coolant additive). make sure before you go tearing your engine apart.
Old Apr 3, 2003 | 05:18 PM
uralman's Avatar
uralman
the oil cooler is in the radiator i presume. are the lines close enough to leak into each other.
Also how can i tell if its the cooler or a head or manifold gasket without oulling it apart?
Paul
Old Apr 3, 2003 | 05:22 PM
uralman's Avatar
uralman
what does this stop leak look like. the stuff in there is a dark slimmy stinky shi_. looks like oil but hard to tell. it sticks to the sides and top of the plastic overflow bottle
Paul
Old Apr 3, 2003 | 05:27 PM
vader86's Avatar
vader86
The oil cooler is not in the radiator, its the finned thing above the filter, if you even have one.
Old Apr 3, 2003 | 05:28 PM
neverendingproject
the oil cooler is sandwiched between the oil filter and block. go to autozone or wherever and get a cooling system pressure tester. pull your oil filter. pump the cooling system up to about 20psi & look for leaks.
from what your describing , it could be either. however , if your cooler is leaking, it'll usually pump your oil into your radiator & out the cap.
if your not losing coolant or oil, id haveta say its additive. a blown head gasket will usually blow your water out the cap due to compression in the cooling system and the oil cooler will do the same due to oil pressure in the cooling system.
Old Apr 3, 2003 | 05:37 PM
uralman's Avatar
uralman
please explain to me how a leaking oil cooler can leak oil into the radiator
thanks,
paul :confused:
Old Apr 3, 2003 | 05:42 PM
neverendingproject
the oil cooler is a heat exchanger. oil runs thru one side, engine coolant runs thru the other..
Old Apr 3, 2003 | 05:43 PM
vader86's Avatar
vader86
IF THERE IS A HOLE OR LEAK IN THE COOLER, ITLL MIX THE COOLANT WITH THE OIL. When the coolant gets back to the radiator, youll have oil in the radiator.
YOU likely have a blown head gasket, but if you EVEN HAVE an oil cooler (its not standard equip) then you might want to check this first.
Either way, unless you managed to pour oil into your radiator, you DO have coolant in the oil.
And you better check it out fast.
Old Apr 3, 2003 | 05:45 PM
uralman's Avatar
uralman
is this common.
paul
Old Apr 3, 2003 | 05:46 PM
vader86's Avatar
vader86
NO, this is why i think you have a blown head gasket.
Blown gaskets are not common, but are the most common cause of this problem.
Old Apr 3, 2003 | 05:47 PM
uralman's Avatar
uralman
Default Re: oil in engine coolant (vader86)
i presume that it could also be a manifold gasket
Paul
Old Apr 3, 2003 | 05:48 PM
vader86's Avatar
vader86
Well, only way to check is to pull it all off and find out.
Old Apr 3, 2003 | 05:49 PM
uralman's Avatar
uralman
got it
thanks for the help
paul
Old Apr 3, 2003 | 09:49 PM
Lone Ranger
What you're seeing may not be oil. It may be sludge build up from old coolant, if its light brownish-orange in color and particularly if it is on the bottom of the reservior sort of stuck to the bottom like pond scum.
Might be worth flushing your cooling system and cleaning out your reservior tank, refilling with fresh coolant, bleed out the air, and put some more miles on it then recheck a few times and see if the suspicious substance returns.
Paul
[Modified by Lone Ranger, 8:59 PM 4/3/2003]
To oil in engine coolant
