Gauges... Digital vs. Mechanical
Old Apr 4, 2003 | 12:47 PM
Garys '92 LT1's Avatar
Garys '92 LT1
Default Gauges... Digital vs. Mechanical
Help!!! On my '92 LT1... I have noticed a difference in the temp readings between the digital readout, and the mechanical gauge... is this a comon problem? For example... the oil temp digital readout will be 205 degree's and the mechanical gauge will read less than 150 degree's. And my coolant temp is doing the same thing... Do I have a relay or a sensor that is going bad? :flag
Old Apr 4, 2003 | 01:17 PM
bogus's Avatar
bogus
Default Re: Gauges... Digital vs. Mechanical (Garys '92 LT1)
:lurk:
Old Apr 4, 2003 | 02:22 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: Gauges... Digital vs. Mechanical (bogus)
there is always (it seems) a difference between the two, it shouldn't be a huge difference, but in my car, the analog is about 20 degrees off or so (or the digital i guess) :D
Old Apr 4, 2003 | 03:19 PM
jimswhite92's Avatar
jimswhite92
Gary,
Do a search on "digital analog gauge" on this forum and you will be overwhelmed with information on this topic.
Jim
Old Apr 4, 2003 | 03:33 PM
pwrful c4's Avatar
pwrful c4
Gary,My 1994 has a difference in the gauges also. :steering:
Old Apr 4, 2003 | 04:00 PM
C4Crazy787's Avatar
C4Crazy787
Yea, same hear Gary. My oil temps are way different, coolant temps are much closeer together. BTW did you get the my e-mail on the cut lid. :seeya :flag
Old Apr 4, 2003 | 05:36 PM
Garys '92 LT1
Default Re: Gauges... Digital vs. Mechanical (C4Crazy787)
Yep, I got your e-mail about the "Cut Lid"... and I'm going to be going that this weekend, as well as the TB bypass.... I made a copy of your e-mail. I really appreciate your input.... THANKS MAN!!!! :flag :steering: :seeya
Old Apr 4, 2003 | 09:12 PM
Jeff M's Avatar
Jeff M
The part of my owner's manual video even mentions this, they take their readings from different sensors. The gauges are just meant to be approximate, with the everything working properly the digital readout is the most accurate.
To Gauges... Digital vs. Mechanical
