Supercharger
Old Apr 9, 2003 | 01:40 AM
Epyon127's Avatar
Epyon127
Default Supercharger
I am interested in supercharging my 1992 Coupe. anyone have a supercharger on an LT-1? What brands, who installs, prices?
Any help would be very appreciated. Thanks
Old Apr 9, 2003 | 03:27 PM
CT95ATLANTA's Avatar
CT95ATLANTA
Default Re: Supercharger (Epyon127)
I have the ProCharger, a pain to install but a nice unit once on there.......mainly the instructions are inadequate......I just clicked over 5K miles on the unit and it's performing as advertised.
Old Apr 13, 2003 | 11:09 PM
Lord Odin's Avatar
Lord Odin
I'm strongly considering getting my done by Carroll. I don't know anyone that has had one done by them though.
Old Apr 14, 2003 | 12:18 PM
vvv90's Avatar
vvv90
Default Re: Supercharger (vetteheadracer)
I'm in the process of installing my procharger.
http://forums.corvetteforum.com/zerothread?id=527005
I will be updating the post soon with more pictures. I've so far only run into minor problems but I'm upgrading the opti and waterpump right now. I'm still nervous about it though. Like Vetteheadracer said, butget for replacing parts. I have plans for a bottom end rebuild I just hope I can get a year or two of enjoyment without having to do that. Clutch is the next "must-do"
As far as cost. I priced installs and I got typical mechanic response. $80-85hr @ 20 Hours! :eek:
As sensitive as a blower setup is to a high compression vette engine, I stand by the motto if you want it done right you do it yourself. I've had bad experience with mechanics making "short cuts" and now that I'm seeing how much of a pain some of the steps are for this install, I'm glad I'm doing it myself. I can take my time. I don't HAVE to get it done in 20 hrs.
:cheers:
[Modified by vvv90, 11:21 AM 4/14/2003]
Old Apr 14, 2003 | 12:23 PM
vetteheadracer's Avatar
vetteheadracer
2022 C7 of the Year Finalist - Unmodified
Default Re: Supercharger (Lord Odin)
I have a 1996 LT4 with a ATI Procharger Intercooled Supercharger, it is the P600B model as quotes 45-60% increase in hp. I had the car dyno'd prior to starting at it had 338HP at the flywheel and 485HP after fitting the kit.
That was when the problems started, car had done 55,000 miles when I fitted the kit.
1. 600 miles later bye, bye clutch.
2. 8000 miles later bye, bye piston.
The lesson here is budget for replacing other parts i.e. new clutch (I fitted a centrforce and that was 30,000 miles ago now).
Engine rebuild - I had J&E forged pistons, Eagle forged rods, Hayes rings, Felpro gaskets (tried GM motorsport ones originally but they blew in less than 3000 miles), ARP bolts, heads ported and ceramic coated. etc., etc.
Also had the suspension upgraded and the brakes to cope with extra horse power.
Also discovered a design fault with the Procharger kit. At 4000 RPM the intake pipe got sucked shut, so had to fit a metal ring inside. Also had fuel pressure problems so fitted bigger injectors. Also had an opti-spark problem (so what's new I hear you say), which caused a mis-fire at about 4500 RPM.
The total cost of the kit, fitting was about $8,000, then spent another $15,000 getting everything else upgraded to cope with all the power.
Now that it all works it is a dream daily driver with 502BHP and 485lbs/ft torque following all of the engine work. It just took 3 years to get everything sorted out.
[IMG][/IMG] I have a 1996 LT4 with a ATI Procharger Intercooled Supercharger, it is the P600B model as quotes 45-60% increase in hp. I had the car dyno'd prior to starting at it had 338HP at the flywheel and 485HP after fitting the kit.
Old Apr 14, 2003 | 12:34 PM
vetteheadracer
Tried to add a picture of the car for your enjoyment, but don't know how to include an image? Anyone help? Tried the Image button, but that doesn't seem to do much except insert a Jave Image Insert.
Old Apr 14, 2003 | 12:43 PM
vvv90's Avatar
vvv90
Yep, just had to learn how to do this myself.
Start by going to http://www.picturejudge.com and open a new account. This is the place you actually will upload your pictures to. After you do that the site is pretty self explanatory for uploading pictures. Once you have the picture uploaded click on the image until it opens in it's own window at full size. Then right click the image and click on properties. Copy the location from the address field to your clip board. Then in your post click on the "Image" button below which gives you: [IMG][/IMG] these tags on your screen. Paste the location in between the tags.
:cheers:
Old Apr 14, 2003 | 02:52 PM
StealDads67's Avatar
StealDads67
I feel the reason that happened to you is because the LT4 has to much compression to supercharge.... and you have to expect a new clutch with that much power.............. But he is right... dont do one if you dont have the moeny for "just incase" problems
Old Apr 14, 2003 | 03:04 PM
dgoodhue's Avatar
dgoodhue
Default Re: Supercharger (StealDads67)
I agree the Lt4 has high compression which doesn't lend it self to SC (10.8:1), but the Lt1 were at 10.4 and the 90-91 L98 10.25:1 I see the bigger problem being the cheap piston that GM used in the engine. The pistons just don't hold up past 450+ hp for a long term reliabilty.
Old Apr 15, 2003 | 08:48 AM
vetteheadracer
Default Thanks for the help
Hi VVV90,
Thanks for the help with the pictures, you are a star.
Just to prove it works, here is my Supercharged LT4
And my brand new 2003 Z06
:cheers:
Old Apr 15, 2003 | 01:25 PM
tjwong's Avatar
tjwong
Default Re: Thanks for the help (vetteheadracer)
I luv your 03 ZO6, you lucky DOG :cheers:
To Supercharger
