Electronic Door Locks
Old Apr 13, 2003 | 01:04 AM
sporanox1's Avatar
sporanox1
Default Electronic Door Locks
I have a 91 and the electronic door locks seem to perform poorly, ie only engaging half-way when I hit the lock button. Any clues or kits to fix this annoying problem?
Old Apr 13, 2003 | 01:26 AM
sumoboy's Avatar
sumoboy
Default Re: Electronic Door Locks (sporanox1)
Is it both doors? If it is then it's too odd that they would go up at the same time. Does it also do it with the drivers side switch that controls both or just individually. If not then it's probably the actuator. Check for binding. Trying to get some idea. :confused:
[Modified by sumoboy, 6:27 AM 4/13/2003]
[Modified by sumoboy, 1:40 AM 4/13/2003]
Old Apr 13, 2003 | 01:37 AM
Lord Odin's Avatar
Lord Odin
Default Re: Electronic Door Locks (sumoboy)
I know my driver side lock sticks sometimes. I have to either hold the button or reverse it in and out a couple times. I think I need to lube it up or something. Does this sound similar to your problem?
Old Apr 13, 2003 | 09:51 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My driver side lock was slow but worked,passenger side went half way. When i did my window seals i got in there and lubed every joint and connection of the door locks and power windows. Everything works great now!! Good Luck!! :cheers:
Old Apr 13, 2003 | 10:20 PM
sporanox1's Avatar
sporanox1
Default Re: Electronic Door Locks (AGENT 86)
I will try that, sounds exactly like my problem.
To Electronic Door Locks
