C5 wheels on C4 ?
Old Apr 13, 2003 | 06:31 AM
95sport's Avatar
95sport
Default C5 wheels on C4 ?
What are the pros and cons to putting the 17" front 18" rear combo on C4s? Do you have to flash the prom to recalibrate the speedo for the size change in rear? Thanks
Old Apr 13, 2003 | 07:38 AM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: C5 wheels on C4 ? (95sport)
:cheers:
Not sure of any Pro's or Cons. Yes if you are going from 17 to 18" rear wheels you will have to recalibrate speedo
:steering:
Old Apr 13, 2003 | 07:49 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: C5 wheels on C4 ? (jackdaroofer)
:cheers:
:steering:
Only if the tire diameter is different. Do some measuring.
Old Apr 13, 2003 | 08:12 AM
johnboy89's Avatar
johnboy89
It depends on the installed height of your wheel tire combo - I lost 2/10th of an inch going to 18" wheels (275/40-17 vs. 275/35-18) - so for me, it wasn't that big of a deal. The Tire Rack at http://www.tirerack.com has all of the specs on the various brands of tires in terms of height, recommended rim width, etc.
I went with 275/35-18, but 285 or 295 18’s might be a closer fit depending on which size 17’s you’re running.
Old Apr 13, 2003 | 10:07 AM
95sport's Avatar
95sport
Default Re: C5 wheels on C4 ? (johnboy89)
Thanks everyone! I'm new to the forum and am amazed at the wealth of knowledge and experience in here, and how willing everyone is to help. Thanks. :)
Old Apr 13, 2003 | 10:34 AM
MrNuke's Avatar
MrNuke
:iagree: Welcome to the forum.. :cheers:
Old Apr 13, 2003 | 12:15 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: C5 wheels on C4 ? (MrNuke)
:iagree: :seeya :cheers:
Old Apr 13, 2003 | 12:50 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: C5 wheels on C4 ? (Mr Mojo)
:cheers:
:steering:
Nice info here: http://www.miata.net/garage/tirecalc.html
Like Mojo said your goal is to keep the same overall diameter. :yesnod:
[Modified by Blue 92, 12:51 PM 4/13/2003]
Old Apr 13, 2003 | 05:55 PM
johnboy89's Avatar
johnboy89
Default Re: C5 wheels on C4 ? (Blue 92)
Not all tyres of identical size are actually the same dia. (or tread width for that matter) - actual size does and tread width does vary somewhat from manufacturer to manufacturer. Point being, check the manufacturers specs closely for the most accurate info when comparing tyres.
Old Apr 14, 2003 | 01:49 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
:cheers:
:steering:
:withstupid: user the right size tire and you will be fine, anything close to 26" works fine :D
Old Apr 15, 2003 | 06:50 AM
Hawaiian Punch's Avatar
Hawaiian Punch
Pro's.....Look's good, con's....speed-o will read about 5 miles off with stock size tires that comes on the 18 inch C-5 rear rim's. :thumbs:
[Modified by Hawaiian Punch, 5:16 PM 4/15/2003]
Old Apr 15, 2003 | 11:03 AM
_freakmonkeydogboy_
Default Re: C5 wheels on C4 ? (Hawaiian Punch)
which is why you should get 35 series tires on the rear instead of 40 series, then you won't be off but maybe 1 mph, which is practically neglegible :D
Old Apr 15, 2003 | 02:19 PM
johnboy89's Avatar
johnboy89
Default Re: C5 wheels on C4 ? (_freakmonkeydogboy_)
If you get 285/35-18’s, they are a ‘perfect’ match (for 275/40-17's)- I bought 275's 'cause the tires I wanted weren't available in 285's at the time from my dealer - plus I saved some money.
I gave up only 2/10ths of an inch in height (i.e., Dia.) - which means my car sits lower by only 1/10th inch (1/10th of an inch less rubber appearing in the wheel well).
Kumho Specs
275/40-17: 25.7” dia
285/35-18: 25.7” dia.
My tires (275/35-18) are 25.5" in Dia.
Old Apr 15, 2003 | 02:30 PM
89L98Coupe's Avatar
89L98Coupe
When I put mine on I noticed I am about 2-3 mph off ? No biggie. I will resize to get close when my Pilot Sports are used up :reddevil :flag
Old Apr 15, 2003 | 10:15 PM
Hawaiian Punch
con's....speed-o will read about 5 miles off with stock size tires that comes on the 18 inch C-5 rear rim's. :thumbs:which is why you should get 35 series tires on the rear instead of 40 series, then you won't be off but maybe 1 mph, which is practically neglegible :D
Which is what I wanted to do, the only problem that I would of had was that I would have had to lower the rear even more in order for me to obtain the look I wanted, and doing this would put me into the "ruff riding" limits that I wanted to avoid.
When the car is lowerd, you dont get much of a change in the ride, untill it reaches a curtain point, which is the point that I'm presently at right now.
You are 100% right though about the speed being only a mile or 2 off. Mahalo and Aloha. :thumbs:
[Modified by Hawaiian Punch, 5:18 PM 4/15/2003]
Old Apr 15, 2003 | 10:42 PM
ScottsLS3's Avatar
ScottsLS3
Wealth? i keep losing it hanging out here!!!!!mods :crazy: mods :crazy: mods!! :crazy:
Old Apr 16, 2003 | 12:01 AM
95sport's Avatar
95sport
Default Re: C5 wheels on C4 ? (ScottsLT1)
Well said! Thanks everyone for your info, input and welcomes. :seeya
To C5 wheels on C4 ?
Old Apr 16, 2003 | 12:17 AM
Epyon127's Avatar
Epyon127
Maybe I'm just silly but when you talk about tires and fractions of an inch I just can't see a giant difference. Wouldn't a new tire and a well worn tire be different in diameter as well as the difference between a properly inflated tire and an underinflated tire. :confused:
Old Apr 16, 2003 | 11:11 AM
johnboy89's Avatar
johnboy89
Default Re: C5 wheels on C4 ? (Epyon127)
...also, if your tires are of a smaller diameter, as are mine, it takes you longer to get where you are going - so you are always having to leave a little earlier than you normally would, which is what I have to do now - after awhile it gets to be a real pain.
I think it has something to do with that space-time continuum thing, but I’m not sure.
Old Apr 16, 2003 | 11:33 AM
ziggy57's Avatar
ziggy57
I installed 285/35x18 rear and 255/40x17 fronts and as far as I can tell the miles per hour is approximately 2-3 mph off. It is worth ot though!
Welcome !!
