C5 wheels on C4 ?
Old Apr 16, 2003 | 04:59 PM
SonnyinVA's Avatar
SonnyinVA
Default Re: C5 wheels on C4 ? (johnboy89)
i would do same size front and rear so that you can rotate them.
if you do 18's in the rear, run them in the front too.
run same width front/rear too.
might as well maximize the life of those expensive tires!
welcome to the forum.
Old Apr 17, 2003 | 06:46 AM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: C5 wheels on C4 ? (SonnyinVA)
i mhave 18s all arond with no issues. I used the "MIATA" calculater ( seen in earlier post) to determine the tire hieght. Notice that on that calculater, it also TELLS you what your speed difference is.
great little tool.
by the way.. I went from 17x285x40 to a 18x295x35 and the tire hieght is virtually the same.
