86 oil pressure good ????
Old Apr 22, 2003 | 10:00 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default 86 oil pressure good ????
Can an L98 with close to 200,000 miles have oil pressure of 60 psi cold, and 45 psi at operating temp? Both readings at idle. Just wandering if sometime in its previous relationships that the motor was rebuilt. The car always starts immediately,burns no blue ands runs strong. :cheers:
Old Apr 22, 2003 | 10:23 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: 86 oil pressure good ???? (AGENT 86)
:cheers: Yes it can!
I have an '82, 305 with 350000 plus that runs 60 lbs cold, 45 pound hot with straight 30w oil
My 88 vette runs 70 + pounds cold and 58 psi very hot, with 20/50 Amzoil Gold
:steering:
Old Apr 22, 2003 | 11:08 PM
vader86's Avatar
vader86
Your pressure is good.
It should be anywhere from 45-60psi at cruise, and half of that at idle.
Cold pressure is going to be higher than hot pressure too.
Mine starts out at about 57psi cold all the time, and then when it gets warm the idle pressure drops to the high 30s/upper 40s, while the cruise stays in the 55psi range.
Old Apr 22, 2003 | 11:15 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Mine had only low 40's when cold with 144,000 miles. After the rebuild I'm back where I should be. Low 70's when cold. 55psi at cruise when hot.
Old Apr 23, 2003 | 09:55 AM
AGENT 86's Avatar
AGENT 86
Default Re: 86 oil pressure good ???? (flyersfan1088)
Thanks for the replys!! :cheers:
To 86 oil pressure good ????
