1/4 Mile time..
Old Apr 24, 2003 | 12:08 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default 1/4 Mile time..
Here is my situation-
I have the mods as described in my sig, with stock exhaust, the stock performance back end (3.07s), a stock torque converter, and street tires. I am currently laying down times in this area:
(last night)
60' - 2.19 (had to have ASR on to even get it down this far.. tires would spin with more then the slightest throttle)
ET- 13.07 (soooo close!! doh!!)
MPH- 107.4
My current upgrade path is as follows-
Nitto drag radials
Cat-Back exhaust system
3.54 gears (in a DANA 44)
2800-3200 Torque Conveter.
Around where should this get me??? Any guesses?
Old Apr 24, 2003 | 12:10 PM
95AquaC4's Avatar
95AquaC4
Default Re: 1/4 Mile time.. (MarkLT1)
12.5's :yesnod:
Old Apr 24, 2003 | 12:28 PM
damionvoss's Avatar
damionvoss
Default Re: 1/4 Mile time.. (95AquaC4)
12.5's :yesnod:
:iagree:
You should pick up some good time with those mods!
Old Apr 24, 2003 | 01:23 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: 1/4 Mile time.. (damionvoss)
Humm.. I'm shooting for low 12s.. maybe I will have to go with a LT header setup as well...
Old Apr 24, 2003 | 01:31 PM
vader86's Avatar
vader86
Hell if you can get that 60' down youd be the 12s now.
Id say that a normal car would get mid/upper 12s, you can probably get low/mid 12s.
Old Apr 24, 2003 | 01:39 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: 1/4 Mile time.. (vader86)
No kidding.. I was fighting my 60' times all night last night.. (althought it was only 44 degrees outside.. which makes it even harder).
What do you mean by a normal car can get mid/upper 12s?? Do you mean if I just got my 60' down? (say, by using a set of nitto's?) Then if I do the exhaust, gears, etc.. I will be mid-low 12s??
Old Apr 24, 2003 | 01:42 PM
vader86's Avatar
vader86
Well judging from what ive seen, most LT1s only run in the low 13s except a very few who, as you have, touched 13.0x. I think yours is a strong one, kinda like Mojo's girl, and if yours can get that low with such bad 60' times then i think as soon as you learn to launch it then youll be pulling high 12s regularly. Then with those mods you might get low/mid 12s.
Old Apr 24, 2003 | 01:44 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Mine is not stock right now though.. I have heads and cam..
Old Apr 24, 2003 | 01:52 PM
vader86's Avatar
vader86
OH well i guess thats what happens if you dont read sigs. :D
Yes, with exhaust/TC stuff you should be in the low 12s.
Old Apr 24, 2003 | 04:46 PM
Vetterin's Avatar
Vetterin
What sig? :confused:
Old Apr 24, 2003 | 04:48 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: 1/4 Mile time.. (Vetterin)
You might have sigs turned off.. They are now turned off by default.
Old Apr 24, 2003 | 05:00 PM
LT4POWR's Avatar
LT4POWR
You gotta love the 13.0xs :cry I'm there with you.
I think your car will really really wake up with the mods you indicated. Probably mid to lower 12s.
Old Apr 24, 2003 | 08:04 PM
Half Fast's Avatar
Half Fast
With your MPH you'd be around a 12.6 with traction and a 1.7-1.8 60'.
Old Apr 24, 2003 | 08:09 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: 1/4 Mile time.. (Half Fast)
Well, I'll be able to let you know soon.. just ordered some good traction.. (nittos)
Old Apr 25, 2003 | 02:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Your potential ET at 107.4mph is around 12.6sec, so a little more HP and gears along with a TC should easily get you those low 12s.
Just pulling a 1.75-1.80 short time would put you around 12.6sec with the current setup. That could be done with maybe a 2,400-2,800rpm TC and sticky tires (and the D44, of course).
To 1/4 Mile time..
