86 prospects
Old Apr 24, 2003 | 07:49 PM
bikerski's Avatar
bikerski
Default 86 prospects
I will pick up my first vett sat. 86 coup, red!!!!!, with 18,000 miles. 1. What will I experience in the next 30,000 for potential problems? 2. Power ant. doesnt work. I'm fairly mech, can I change/where do I purchase? :auto:
Old Apr 24, 2003 | 09:37 PM
wirenut3's Avatar
wirenut3
Default Re: 86 prospects (bikerski)
Hi I just biught a 1986 Vette AND it was in mint cond except tires so I put on A set of tires then the window regulator went bad then the O2 sensor went out and the upper intake sensor then the AC so had it changed to 134A then the headlight motor gears went out so right now I have A nice vette lololol :cheers:
Old Apr 24, 2003 | 09:38 PM
vader86's Avatar
vader86
With such low mileage i would definitely change every fluid in the car to synthetic, id change the tires and give the brakes a once over.
But nothing else stands out.
Electrical things like the alternator/battery/sensors might go on you.
[Modified by vader86, 9:39 PM 4/24/2003]
Old Apr 24, 2003 | 09:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
18,000 WOW!!!! Where did you find this virgin!! I'm approaching 200,000!! :thumbs: :cheers:
Old Apr 24, 2003 | 10:29 PM
dgoodhue's Avatar
dgoodhue
I would go through and change all the fluids. I have read that a common problem with ultra low mileage L98's is that the injectors tend go bad.
To 86 prospects
