I have not been able to figure it out yet. Iam losing patience and becoming frustrated.
So far...here's whats been done:
Replaced Drivers Side Caliper
Replaced Brake Pads
Replaced E-brake cable to left (drivers side) (cable had a kink in it...so figured better replace it)
I have tried pulling up on ratchet 3 or 4 times to readjust it.
all said and done iam right back at square one.
pulling it up to full on position will NOT hold the car...it still rolls
Re: ?#$% E-Brake Still Don't Work!!!! Need Help! (XtremeVette)
I adjusted mine using the info in haynes manual. Now i feel like i could park on a wall. Did you adjust the shoes thru the hole in the disc? Did you slacken park brake cable before doing the shoe adjustement?
:cheers:
Re: ?#$% E-Brake Still Don't Work!!!! Need Help! (AGENT 86)
iam sorry.....my b....I never put up information on the year of my car......which is a 1990....so it differs from the 87-89 setups....I don't have an equalizer and from what I have read in both my haynes and Helms manuals....there is no fine tuning at all...except by cranking the adjuster up a couple of times....but hey if I have overlooked something....please somebody chime in!
