Bose Speakers
Old May 4, 2003 | 12:24 PM
cshuman's Avatar
cshuman
Default Bose Speakers
One of my front speakers has started making a hissing sound even when the volumn is turned down. Does this mean I need to replace the amp board in it? :confused:
Old May 4, 2003 | 05:20 PM
cshuman's Avatar
cshuman
Default Re: Bose Speakers (cshuman)
ttt
Old May 4, 2003 | 06:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Chances are the caps need replacing in the amp.Check theses out for info. http://12.212.62.128/old_proj15/old_proj15.html http://www.zr1.net/amp.html http://www.zr1.net/Bose2.pdf https://www.corvetteforum.com/techti...D=91&TopicID=2 https://www.corvetteforum.com/techti...D=58&TopicID=2
:cheers:
Old May 4, 2003 | 09:17 PM
Louis J Hoppmann's Avatar
Louis J Hoppmann
Call Doctor Don he can fix you up. http://www.doctordons.com/
Old May 4, 2003 | 11:54 PM
efi's Avatar
efi
yeap... save the money and do it by yourself... or take it to someone to do it for you (as I did)... I've fixed 4 amps and they all work... (for $25 all 4 amps heheh) :cool:
You just need to look for and replace leaking capacitors... I used the ZR-1.net guide as my reference... good luck
Old May 5, 2003 | 12:30 AM
86Moon's Avatar
86Moon
DrDons may do good work, but either the owner or someone working for him is a total AHOLE. There are lots of good cheaper alternatives :rant:
Old May 5, 2003 | 05:01 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Bose Speakers (86Moon)
I haven't dealt with them, but what makes you say that? The general consensus here seems to favor their service.
Old May 5, 2003 | 08:03 AM
Red Tornado's Avatar
Red Tornado
The best long term advice is to forget about Bose all together, rip the junk out of your vette and get a decent aftermarket system. You'll be glad you did :cheers:
Old May 5, 2003 | 10:41 AM
Bodhi's Avatar
Bodhi
Default Re: Bose Speakers (bradvette)
:iagree:
The Bose stuff was outdated garbage when these cars were brand new....even a Sony from WalMart will sound 10X better
Old May 5, 2003 | 07:04 PM
cshuman's Avatar
cshuman
Default Re: Bose Speakers (Bodhi)
Ok, I wanted to keep it original, but maybe I should do this. Do you change the wiring and all the speakers along with the system? Or does someone make a wiring harness that allows you to use the existing wiring?
Chuck :confused:
Old May 5, 2003 | 11:51 PM
bogus's Avatar
bogus
it ain't that simple. the blose system is so integrated.
I don't think it was behind the times, just not very good quality for the $$.
The drivers are junk.
I would suggest moving this over to the audio section.
You will need to run new wire. it will be better in the long run.
To Bose Speakers
