Unknown Plug 87 Roadster
Old May 6, 2003 | 09:06 PM
BCinPhx's Avatar
BCinPhx
Default Unknown Plug 87 Roadster
Hi Everybody, been gone for a while....
Anybody have a clue what this plug is for, much less where it goes? I did some work to the intake and found it stuffed under the plenum and the repair mauals, etc. - I can't find what it is. I hope this picture comes out.
:confused:
It's pink/black and the other one is gray..I'll have to recheck which one is hot and the plug is broken and was taped-up. It comes out of the left side where all the injector wires run and is only @ 6 inches long.
[Modified by BCinPhx, 7:08 PM 5/6/2003]
[Modified by BCinPhx, 7:23 PM 5/6/2003]
Old May 6, 2003 | 09:40 PM
Siveck's Avatar
Siveck
Default Re: Unknown Plug 87 Roadster (BCinPhx)
My guess is that it's for the EGR control solenoid which seems to be missing on your car. The control solenoid should be located under your thermostat bolt in the picture. I also noticed that the vacuum lines for that solenoid seem to be bypassed or something in your picture. So, is your EGR disabled? That is my theory, anyone else have any idea?
Old May 6, 2003 | 09:49 PM
BCinPhx's Avatar
BCinPhx
Default Re: Unknown Plug 87 Roadster (Siveck)
I will check out the EGR valve and see if anything is in the manuals I have. I wonder if the fact that it's maybe missing (assuming that my model year had one) might just be the cause of at steady throttle on the freeway/interstate, the car varies constantly in RPM. I thought it might be caused by the rebuilt tranny and the associated pressure adjustment linkage,,,,,hmmmmm
Old May 6, 2003 | 09:52 PM
scorp508's Avatar
scorp508
Hmm... lemme see if I can find it on mine. Yup, EGR valve solenoid. If you still have it, it should be on a bracket held in place by the rear thermostat neck bolt.
[Modified by scorp508, 9:54 PM 5/6/2003]
Old May 6, 2003 | 10:12 PM
BCinPhx's Avatar
BCinPhx
Default Re: Unknown Plug 87 Roadster (scorp508)
Ain't there...now what? Oh boy!
Old May 6, 2003 | 10:17 PM
scorp508's Avatar
scorp508
Tape it up and forget about it if it isn't anywhere. :)
Old May 6, 2003 | 10:20 PM
Siveck's Avatar
Siveck
You don't need the egr as long as all vacuum ports are sealed and exhaust is blocked off unless you have smog testing. Some will argue about this, but egr just dumps dirty and crappy exhaust back into your clean intake. As far as the surging on the highway, that should be unrelated to the egr. If your car is an automatic, I would suspect that the torque converter is not locking up as it should on the highway.
Old May 7, 2003 | 07:50 PM
BCinPhx's Avatar
BCinPhx
Some good ideas....any more - please
Old May 7, 2003 | 08:32 PM
VetteNoob's Avatar
VetteNoob
Wat they said. Mine was unplugged too when I got the car, I just semi-pushed it back on the solenoid, but I have no emissions so I dont think it is serving any purpose at this point. Plus I had the EGR programmed out of my ECM (no more code 32).
Old May 8, 2003 | 01:27 PM
SunCr's Avatar
SunCr
That dirty crappy exhaust lowers combustion temps by about 500 degrees helping to prevent detonation. If you're running stock or have questionable gas, keep it hooked up.
Old May 8, 2003 | 01:59 PM
vetracer's Avatar
vetracer
Default Re: Unknown Plug 87 Roadster (SunCr)
Interesting - How does hot exhaust air lower combustion temps?
Old May 8, 2003 | 02:12 PM
SunCr's Avatar
SunCr
Default Re: Unknown Plug 87 Roadster (vetracer)
With the fuel & air gone, the exhaust is inert and acts as a heat sink, at least that's the engineering behind it. You can accomplish the same thing with a little more overlap in the cam, which is what later model hi-po engines do, eliminating egr. You have to be careful regardless of what system is used. Too much exhaust, you'll put out the fire.
To Unknown Plug 87 Roadster
