Roller Cam???
Old May 16, 2003 | 11:31 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Roller Cam???
Can a roller cam be used on a built up L83 engine?????? Without special maching??????
Just FYI...
thanks
tony
:eek:
[Modified by oldace84, 8:32 PM 5/16/2003]
Old May 16, 2003 | 11:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Roller Cam??? (oldace84)
I don't think it would require special machining but it would require lifters with links to prevent rotation along with a cam button at cam cover to prevent the cam from "walking" forward.
Old May 17, 2003 | 12:10 AM
vader86's Avatar
vader86
There is an adapter kit for it, but you might as well use the old style with that engine.
Old May 17, 2003 | 07:37 AM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Roller Cam??? (vader86)
Im using my 73 block with comp. cams retro. style lifters,comp cams 7.4 pushrods,and a crane roller cam button.Lately theres a been a few guys with the same lifters on the c3 forum and there links have broken and wiped out there cams.
Old May 17, 2003 | 03:41 PM
CFI-EFI's Avatar
CFI-EFI
Underneath that funky manifold is a normal medium performance Gen I 350 engine. All pre-roller engine parts fit like any other Gen I engine. The L83 shouldn't be such a mystery. Even the heads and cam are similar, if not identical to, early L98's. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
To Roller Cam???
