86 hypertech chip
Old May 19, 2003 | 10:53 PM
bikerski's Avatar
bikerski
Default 86 hypertech chip
installed a hypertech chip on my 86. Hated the low speed, low excelleration shifting before, super now. I think the horsepower is up but the shifting improvement is worth the money. I was shifting out of OD in town. Dont have to now! Anyone know the real HP improvement on a pretty stock 86?
:auto:
Old May 20, 2003 | 12:15 AM
vader86's Avatar
vader86
Default Re: 86 hypertech chip (bikerski)
0
Old May 20, 2003 | 12:57 AM
Mach85's Avatar
Mach85
This has been beat to death Vader is right 0 HP it simply holds in gear a little longer and kicks your coolant fan a little earlier thats about it for most chips depending on which one you have.
Old May 20, 2003 | 06:27 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: 86 hypertech chip (Mach85)
C'mon guys! I think zero is a bit harsh. Seriously maybe 3-5 RWHP on a stock motor. The difference in shifting you are feeling is because the torque converter lock-up is delayed more than before.
Hypertech gets an extremely bad rap around here. When I had my motor rebuilt with ported heads and a TPIS cam, it already had a Hypertech in it. I sold the chip and put the factory PROM back in while waiting for my new chip (thanks again Jesse :cheers: ) The car went from a bad tune to a horrendous tune immediately. They Hypertech is different enough from stock that it did actually have some tuning capabilities on my new motor setup. I'm speaking from experience, not from what I've heard others say. So many people who have absolutely no experience with Hypertech rip on it because others have said similar things. And so the legend grows.
Having said that, I am in no way endorsing Hypertech. If you have enough mods to even need a chip, a custom burn is the only way to go. But Hypertech will give you more than 0 hp. Maybe not much more, but more nonetheless
[Modified by flyersfan1088, 5:35 PM 5/20/2003]
Old May 20, 2003 | 11:11 PM
bikerski's Avatar
bikerski
like I said, the shifting improvement is enough for me. seems like the rear tires break a little easier but may be I'm just getting used to driving my first HP car. :steering:
Old May 21, 2003 | 12:01 AM
vader86's Avatar
vader86
all the damn thing does is advance timing, i can do that myself
Old May 21, 2003 | 12:20 AM
flyersfan1088
Default Re: 86 hypertech chip (vader86)
Untrue. You can change BASE timing yourself, but you can't alter WOT timing without going into the chip itself. It also delays torque converter lock-up, which can't be done by turning the distributor underneath the shadetree. Again speaking from experience, as I have actually USED one, there is more to the chip than most people give it credit. As far as their claimed 20 hp on a stock motor, I've gotta scream :bs . But there is more to it than simply advanced timing.
To 86 hypertech chip
