WHERE TO PUT THE MAT SENSOR ???
May 23, 2003 | 08:13 PM
I installed the miniram and ATI supercharger, I hate to put the mat sensor in one of the S/C tubes, any idea on a good place to install it ?
Thanks,
Rich
May 24, 2003 | 12:34 PM
Re: WHERE TO PUT THE MAT SENSOR ??? (RICH86'ZZ4)
I've got mine installed in one of the rubber tubes. Drilled a hole, and stuffed it in. Seals nice and tight, and stays put.
May 25, 2003 | 08:02 AM
Re: WHERE TO PUT THE MAT SENSOR ??? (Fast Glass)
I left my MAT sesnor mounted in my Mini-Ram. The kit had a relocation sensor, but I figured the boost would blow it out of the tubes, as it was just a rubber grommet fixture.
Was I wrong? Will relocating the sensor make that much difference?
Steve
May 27, 2003 | 08:00 PM
FAST GLASS, I'm running 10#'s of boost, do you think it will stay put ??
May 27, 2003 | 08:02 PM
Re: WHERE TO PUT THE MAT SENSOR ??? (steveelsbury)
Steve, I called TPIS and they told me to install it in the supercharger tube.
Rich
May 28, 2003 | 11:36 AM
Rich
:skep:
May 28, 2003 | 04:42 PM
Rich - well, that's from the horses mouth! Did you do so? Does it stay in under boost?
Krivera - what emotion does that little purple thingy convey?
Steve
May 29, 2003 | 11:33 AM
Oh yeah. I was running 10#s, just upgraded to 12.
May 29, 2003 | 12:45 PM
steve it is Skeptical i was just saying because i would think it would blow out or something? but what do i know?
but if it works then :D
May 29, 2003 | 02:05 PM
Re: WHERE TO PUT THE MAT SENSOR ??? (krivera)
KRIVERA, I feel the same way, I think it would blow out.
Steve, I'm still looking for a spot.
FAST GLASS, 12#'s of boost and it stays put, maybe I'll give it a try I just hate to put a hole in the S/C tube.
I was thinking of putting it in the end of the air filter, I don't know if it will get a good reading though, any thoughts on that ??
Rich
