I am running their AFR gage and it works great also I'm running their bottle heater and their purge kit they both work great. They have a lot of nice stuff, check it out. Oh and I have nothing to do with this place. I just like their suff and want to share...
Thanks for the info. I emailed to a friend of mine who does hipo work on cars. He does alot of nitrous installs so he can use this. Saw a 90 vette with 383 w/ 8.5 c.r. with a 200 hp kit he did the other day. As soon as I get my camera back I will shoot some pics of his stuff and post them.
My new pro version Gen.7 dfi has that built into it. Not only will it shut the nitrous off but you can program what A/F ratio that you want it to shut it down at. The new Gen.7 is so advanced that probably a lot of people don't realize just what all it can do.
Sorry to bust your bubble, but a stock GM or for that matter any narrow band O2 sensor cannot be counted on to be reliably accurate to measure outside their band. That means that anywhere outside the stoichmetric area (450mV) these sensors are inherently inaccurate. Tests have proven time and time again that even at 850mV and higher, AF ratios vary greatly, yes its rich but by how much?
On repeated dyno tests, using a Horiba AFR meter narrow band O2 sensors have varied by as much as 1 AFR point in the high and low regions. Do you really want to trust something like that? If you really want to do something like that then use a wide band O2 sensor, they measure accurately through a band of 10 to 20:1 AFR.
