Shocks
Old May 25, 2003 | 08:01 PM
Jerry D's Avatar
Jerry D
Default Shocks
For regular driving which shocks are better Bilstein or Edelbrock?
Old May 25, 2003 | 08:07 PM
vader86's Avatar
vader86
Default Re: Shocks (Jerry D)
I would say for a cruiser/weekend car that Edelbrock IAS is better, its firm enough that you can get a little spirited and soft enough that you dont feel every bump in the road.
Bilstein is stiffer, more like an Autocross shock.
Old May 25, 2003 | 08:10 PM
Jerry D's Avatar
Jerry D
Default Re: Shocks (vader86)
Which ones do you have and what year is your vette?
Old May 25, 2003 | 08:13 PM
vader86's Avatar
vader86
86, Bilsteins
Although ive ridden in someones 90 that had the IAS, and kinda like the softness.
Old May 25, 2003 | 08:27 PM
Jerry D's Avatar
Jerry D
That's what I got. Edlebrock's are more expensive But maybe it's worht it?
Does your 86 sit low in the front?
Old May 25, 2003 | 11:17 PM
vader86's Avatar
vader86
It depends on how you drive it as to which you pick, you could just call Bilstein and have something custom-valved to be not so hard and maybe thatll come out cheaper than a new set of Edelbrocks. I thought that the Bilsteins were more expensive, i guess everybody else raised their prices.
She sits just fine in the front, but I would expect new shocks to raise it by almost an inch if the current ones are bad.
[Modified by vader86, 11:18 PM 5/25/2003]
Old May 25, 2003 | 11:19 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Bilstein :thumbs:
Old May 26, 2003 | 01:30 AM
Jerry D's Avatar
Jerry D
My 86 sits very low and scrapes the air dam a lot.
I'm going to be replacing my front leaf spring and shocks soon.
Old May 26, 2003 | 09:16 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Shocks will not raise or lower a car, since even the gas-charged ones support virtually no weight.
I just took the Bilsteins (60k miles) off my '96 and replaced them with Edelbrocks. The Edelbrocks are slightly stiffer on smooth roads (this may be a function of the miles on the Bilsteins) and control 'stutter-bumps' just a tad better. Other than that, not much difference.
I'm thinking that new Bilsteins would have done just as good a job at 66% of the price. (At least the Edelbrocks match my Corvettes color.....)
Larry
code5coupe
:seeya
Old May 26, 2003 | 09:31 PM
Jerry D's Avatar
Jerry D
Default Re: Shocks (rocco16)
Thanks. It sounds like Bilstein's will be the cheaper way to go and just as good as the Edelbrocks.
Old May 27, 2003 | 12:30 AM
vader86's Avatar
vader86
Shocks will not raise a car
Oh yes they will, if your suspension components are worn, and that doesnt necessarily mean if your spring is delaminating.
Old May 27, 2003 | 12:39 AM
BAM92's Avatar
BAM92
I am the only vette I know of running Tokico blue shocks. Not bad. Handle well as my Bilsteins but don't beat me up on Houston's bad roads. I got them for 160 a set. Figured I would give them a try.
To Shocks
