HOT CAM INSTALL ( do you have to remove the oil pan???)
I talked to a mechanic today to get a price on the install of a hot cam. He said he would have to take the motor out, because the oil pan must be removed. I trust this guy, but I was just try9ng to see if he didn't want to mess with the job.
Re: HOT CAM INSTALL (NickC493)
You need to remove the oil pan to get the front cover off, but you can do this with the engine in the car. Actually, you could just loosen all the oil pan bolts and just let the front hang down out of the way.
For him, in the long run, it might be easier to take the engine out. Then it would be easier to use all the standard tools that might be too hard to use with the engine in the car. Besides, he might be able to do a better job with the engine out. Anything else you want to do if you chose to take it out? You could clean/paint the engine compartment, maybe paint the engine, lot's of possiblities.
Re: HOT CAM INSTALL (Zix)
I installed mine with the engine in the car....if I did it again I would pull the motor I can't see it being any harder than the way I did it.... If you want to keep in in the car, you need to loosen every oil pan bolt, the front is not going to come down without the rear bolts being undone also. Good luck :cheers:
Re: HOT CAM INSTALL (MongooseLT4)
I can do a cam swap in my car in 10 hours from start to finish. If I pulled the motor to do the cam swap it would take me twice that at least (and yes I have pulled it several times).
One of the issues to consider is contamination to the main bearings when pulling the cam. There is a high probability that this will happen. It is therefore recommended that the engine be pulled and the main bearings be replaced with thicker bearings. The LT1 has a very light main bearings and are easily damaged if any debris gets to this part of the engine. On the LT4 this is not the case for some reason GM used a better main bearing.
Contact MTI on the forum for expert advice. Good luck !
:seeya
[Modified by red-y, 7:24 PM 5/29/2003]
[Modified by red-y, 7:26 PM 5/29/2003]
:seeya
Re: HOT CAM INSTALL
Go here and check out this detailed cam installation tutorial into a C4
http://www.hashmarks.com/techtips/hot_cam.htm
And yes you need to remove the oil pan, and to do that you will have to raise the engine off of its mounts about 3/4 of an inch. You will also need to raise the engine in order for the cam to clear the front cross member as well.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: HOT CAM INSTALL (tjwong)
You don't need a cherry picker because you don't have to raise the engine to remove the pan. Turn the motor over to just the right spot so the crank counterweights are pointing upwards. (both #1 and #2 way down at equal heights in the cylinders... with some deep thought, you could determine at what crank position this occurs at).
I have an L98, so it could be different clearances, I could be wrong.
Re: HOT CAM INSTALL (CentralCoaster)
True you can get the stock pan of without lifting the motor on LT1's as well. You do have to lift it about 1" in the front in order to get the cam out though. I have done it where I disconect the passenger side motor mount from the bottom and lift it that way with a hoist. it gets plenty of room to remove the cam that way. It may be just as easy to unbolt both motor mounts and lift it as a whole.
Chris
Chris
Re: HOT CAM INSTALL (Vette92)
Ah. Of course. But couldn't you also drop the back of the motor down too to angle it up? I guess that could possibly be even more labor intensive though: removing the driveshaft and loosening the torque beam.
I haven't actually done a cam yet. But I did look closely at the prospect of it while doing my intake and timing set recently.
Re: HOT CAM INSTALL (crash1mac)
:D If I wasn't traveling so much I would surely help you do it. I am only home about 4-6 days a month right now.
Chris
Chris
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
first i need to do my intake cuz im leaking oil i hate that smell I havent owned a tpi that wasn't inder warrenty before so it will be first time doing it im going to just do it one day anytime you have when possable to help a brother out would be apreaciated.
Hell ill even buy the beer and feed ya ect.
Brian
Brian
Gotta pull the intake to do the cam. I do not know the TPI motors like I do the LT1's, but I could still help ya.
No you may not have to lift the engine to remove the oil pan. But for me seeing how the bolts was out of the motor mounts to lift the motor to get the cam out anyway. I can assure you that it was definitely easier to get the pan out and to get it back in with an inch or two of added clearance.
:leaving:
[Modified by 96GS#007, 9:50 PM 5/31/2003]
Re: HOT CAM INSTALL (DRAGRCR1005)
Yes I pull the trans first (ZF). No I do not have a lift and I do all my work on 3 to jack stands. I do have my own engine hoist though.
I have heard of people leaving the ZF trans in there when pulling the motor, but I find that just senseless and adding much more difficluty to the process of putting it back in.
The first time I pulled the motor I was with two other frends and we did an engine swap over a span of about 20 hours. That was simply pullnig mine and putting another one right back in. Would have taken less time if we had not fiddled with trying to install the tranny with the wrong size throwout bearing. 2+ hours wasted trying to figure out why it would not slide in.
I can have the motor out myself in about 8 hours I would estimate. That is with taking my time, pulling all the accessories off of it, organizing bolts, stopping for food and beverage, and dropping the tranny. :cheers:
Re: HOT CAM INSTALL (96GS#007)
:iagree: :yesnod: Maybe L98s are different, but on LT1s and LT4s it's a matter of loosening two nuts and throwing a floor jack under the sucker. Takes what?...5 minutes on a bad day?..and gives you more room to work. I fail to see the downside to this approach.
On my 85, it's a lot of work to remove the oil pan. I have to remove the starter, flywheel dust cover, oil cooler lines, and all those stupid wire harness clips that are attached to the oil pan bolts.
